606 exhaust build questions.....?
Good morning all.. I'll try to keep it short. I' m going to fit a 3 inch exhaust to my G like the one on dieselpump UK.. Great work there if you have not visited. It has a std length silencer and the pipe exits in front of the rear wheel. Should i use a short length of flexi coupling just after the turbo? This would be a weak point as the old factory one split here, it would also have to be a clamp on or bolt on connection so it could be replaced if it did split.. Gases can also escape at these joints.
Would it vibrate or move too much for the rubber silencer hangers to handle if no flexi used?
(05-16-2015, 04:14 AM)elvis100 Good morning all.. I'll try to keep it short. I' m going to fit a 3 inch exhaust to my G like the one on dieselpump UK.. Great work there if you have not visited. It has a std length silencer and the pipe exits in front of the rear wheel. Should i use a short length of flexi coupling just after the turbo? This would be a weak point as the old factory one split here, it would also have to be a clamp on or bolt on connection so it could be replaced if it did split.. Gases can also escape at these joints.
Hi Elvis,
I run a 80 mm which is nearly 3.5 inch flexible down pipe to 80mm muffler below the driver (rhd) under the sill with a side exit. You will need a mild bodylift though to ket the flexi pipe clear the chassis and bosy with this route.
By the way, you wouldnt be the elvis from difflock forum who lives in Wales?
Cheers
Richard
