STD Tuning Drivetrain Gas vs Diesel W115 M/T
dalek
09-06-2009, 09:27 AM #1
What are the differences between, say, a manual transmission off a W115 gas car and a diesel one? How about the flywheel?
I am not here to make waves; Sois jeune et tais toi
dalek
09-06-2009, 05:48 PM #2
The gas engine flywheel is far lighter. Transmission is the same.
dalek
09-07-2009, 06:25 AM #3
Thanks for the info! I wish I had someone's number while I was there. Now, I think I want that flywheel. About the transmission, even though it was a 1970 W115 4 cylinder gas engine (220?), its transmission had an aluminum housing. Based on your post about when each transmission was used, http://www.superturbodiesel.com/std/manu...ml#pid4151, does that mean it perhaps was replaced during its life?
I did get the pedals and shifter. Will have a friend get me the driveshaft. Next time I go there, if the transmission is still there I may do some deciding. I do know I want the flywheel.
dalek
09-07-2009, 10:38 AM #4
The bell housings are aluminum on the older transmissions and the transmissions are cast iron!
the newer ones after 82 are all aluminum! inter graded bell housing one piece!
dalek
09-07-2009, 10:56 AM #5
I am sorry for daring to consider the body of the transmission I saw to be aluminum instead of cast iron. As my signature indicates, I am not here to disagree with those with higher rank than me. So, I do apologize once again for being so dense.
Eppur si muove
dalek
Eppur si muove
09-07-2009, 04:29 PM #6
it may have been replace with a newer one? check this out you can identify witch one it is with some pics http://superturbodiesel.com/std/manual-t...t-421.html
