716.654 Gearbox
716.654 Gearbox
(05-30-2015, 11:15 AM)Frank606 hi guys
Will a Sachs 765 cover fit this gearbox a 220cdi 716.654 6 speed
And Where can I buy a good solid mass sprinter fly wheel from
ThanksR
ThanksR
(08-12-2015, 12:44 PM)barrote evopeter
do u have a 716 gear box , and how did u manage the odometer? i´m stugling and starting to have nightmares about it
the prop shaft is kind of easy like the flex coupling,
at least for me , the trouble in in getting the odometer, to go from mechanical to electric. do u know of any W124 cluster in electronic? or any other that i can fit the insights?
wich flywheel are u using?
(08-15-2015, 04:33 AM)barrote the prop shaft is kind of easy like the flex coupling,
(08-15-2015, 05:04 PM)barrote yep w 126 , i see ... thanks , i just use a c270cdi flywhell along with the box out of a w212.
works ok. at least with my 300hp 605.... i belive.
ok say something when u finish that w126 thing
