STD Tuning Engine 1997 E290 Glow Plug
1997 E290 Glow Plug
1997 E290 Glow Plug
dude99
06-29-2015, 08:22 PM #1
Hey all,
Just bought myself a 1997 E290 (2.9L OM602.982), which I love so far. However I'm relatively certain that I have 0 out of 5 glow plugs working, based on how hard it is to start.
My only issue is that I'm in North America, and the E290 was never imported here, so no one has a listing for what glowplug it uses.
So my question is, does anyone know the Bosch part number for the glowplug these use?
dude99
Hey all,
carlitosgy6
Ranger Turbodiesel
144
06-29-2015, 08:44 PM #2
http://www.rockauto.com/catalog/raframec...=Engine&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=02uvorqsji891n1ptf41fbvvn7 search glow plug they have them
carlitosgy6
dude99
06-29-2015, 09:05 PM #3
Thanks. I did see that before however, they don't list a bosch plug either. I was hoping for a Bosch number as they are readily available at my local parts store.
dude99
dude99
06-29-2015, 09:38 PM #4
hmmm, found the bosch number
0 250 202 140 or GLP021
Seems that nothing in NA uses this glow plug.... how frustrating... Anyone know otherwise?
dude99
Petar
7.5mm M pump
459
06-30-2015, 01:25 AM #5
Are you sure the problem is in the glow plugs ? The E290 has a direct injection engine so it should start easily even with no glow plugs at all as long as the ambient temperature is above 5-10 degrees celsius.
Petar
dude99
06-30-2015, 09:45 AM #6
That's actually a very valid point. The car was sitting in the 30*C sun all day and the temp gauge bumped up off the 40* line when I turned the key on. So the engine was pretty warm all things considered. It still took about 5-6 cycles of the starter to get it to catch. As such I'm going to agree, the glow plugs probably aren't the issue here.
The PO mentioned that he thought the hard starting was a result of an air leak in the fuel system. He thought he had seen bubbles in the clear lines leading to the filter assembly. I can also smell diesel while driving it, so I know I have a leak somewhere. It looked to me like the return lines are weeping (this will be fixed tomorrow). Could a leak cause the fuel system to loose its prime after a couple hours to the point of hard starting? I'd also like to replace the O-Rings that the seal the fuel lines but have been unable to ascertain what size they are. Are they a standard metric size that would come in an O-Ring kit or are they a dealer only item?
-thanks for the help so far
dude99
Petar
7.5mm M pump
459
06-30-2015, 12:55 PM #7
It is possible that you lose prime in the system due to an air leak.
I don't know about the O ring sizes. They are a common problem on W202 and W210 chassis turbodiesels.
Does that OM602 have the same style quick coupling hoses as the OM605 and 606 engines ? If they are then it is very likely that the O rings are your problem. Hell some people had to replace all the hoses until the car would start.
Petar
dude99
06-30-2015, 02:05 PM #8
Haven't seen a picture of the om606/605 ones, but seeing as they are the same chassis and the same years I'd bet they are the same.
Do they just pull out? I haven't been able to find a DIY on them yet.
dude99
carlitosgy6
Ranger Turbodiesel
144
06-30-2015, 04:57 PM #9
bosch part numbers interchanged from the ones on rock auto but verify by yourself
0250202029 0250202039 0250202045
This post was last modified: 06-30-2015, 05:00 PM by carlitosgy6.
carlitosgy6
dude99
06-30-2015, 05:16 PM #10
Awesome, thanks Smile
Just got off the phone with the dealer ordering all the o-rings. I was pleasantly surprised that it only came to $30...
dude99
Petar
7.5mm M pump
459
07-01-2015, 12:11 PM #11
A quick test you could try in the meantime is to disconnect the fuel supply line from the tank and connect it to a fuel can above the engine level. When you shut off the engine air won't get into the lines since the fuel is slightly pressurised by gravity. If it starts fine then you have isolated your problem.
Petar
dude99
07-01-2015, 12:38 PM #12
I found the leak last night after I got home. Turned off the car and waited a few minutes. I could see air bubbles rising up though the hard line running from the IP to the fuel filter. It looked like it was leaking from the connection at the pump. I believe there is a copper crush under that connection which I also ordered with the O-rings from the dealer.
The other hard line running from the fuel filter to what I believe is the fuel heater was also wet. So I'd say air leaks a plenty is the issue here...
dude99
