STD Tuning Engine R134 intercooler?
R134 intercooler?
R134 intercooler?
atypicalguy
07-18-2015, 12:06 PM #1
Is the heat pumping capacity of the stock air conditioner compressor large enough to effectively intercool say 3 bar of boost on an OM617? I'm guessing not, but I don't know.
I know lots of people remove AC to fit an intercooler, but it seems easier to just reuse it for an air to R134 setup.
Thanks
atypicalguy
Thanks
led-panzer
07-18-2015, 01:45 PM #2
Seems any gain you'd make with the cooler air would be nullified by running the A/C compressor no?
An air/air intercooler is "free" cooling
This post was last modified: 07-18-2015, 01:46 PM by led-panzer.
1985 300D 280,000 miles RIP
led-panzer
atypicalguy
07-18-2015, 01:57 PM #3
Interesting question, but I think not.
If we assume that the compressor can provide similar cooling to an air to air intercooler, then we know we can cram more pounds per minute of air into the motor, which allows us to put more fuel in, which provides a great deal of power. You are correct that it would not be as efficient as an air to air, because the AC compressor, like the turbo compressors, are not 100% efficient, so it takes some power to cycle the coolant through the system as it is compressed and expands. But that is like 5-10hp maybe. How much hp gain does efficient intercooling allow? A bunch. I'm thinking 20-30hp.
I think this would require a reservoir for the coolant somehow. Under high load/boost it would run behind, but then it would catch up under medium/low loads.
Here is a vid of how it might work dynamically: https://www.youtube.com/watch?v=AaQRwNmt7lY
atypicalguy
atypicalguy
07-18-2015, 02:02 PM #4
http://activeinterchiller.com/
atypicalguy
Edian727
Dreams of 8mm 617
127
07-19-2015, 10:07 AM #5
so you'd put the part that gets cold in your intake like a a/w but with the cold side of the a/c in the intake. I imagine it'd work. I see that activeinterchiller use's the a/c to cool a a/w intercooler, but why not just put the cold side in the intake?
interesting, i've always thought about using one of those 12v powered cooler for food in your car as a resevoir for you a/w, but i think this might be better. both put draws on the system, i just dont see the draw being more then the gain.
Edian727
atypicalguy
07-19-2015, 11:35 AM #6
I think they use the water as a heat sink. They make it really cool, then it warms up a bit when you nail it. Then it cools off again when boost is less..
This post was last modified: 07-19-2015, 04:25 PM by atypicalguy.
atypicalguy
baldur
Fast
511
07-19-2015, 12:21 PM #7
3 bar boost on an OM617 will give you something like 15kg/min of 200°C air if you have a 70% efficient compressor. Cooling this air down to say 40°C removes 40 kilowatts worth of heat out of the system. I don't know for sure how much heat the AC compressor is able to move but it's not that much.
Baldur Gislason
baldur
Baldur Gislason
07-19-2015, 02:33 PM #8
...and it draws a sh!tload of power when engaged...
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
atypicalguy
07-19-2015, 04:35 PM #9
I think the power draw cannot be more than 5-10 hp.
It seems like it is used to supercool (ie below ambient) the water in an AW intercooler, rather like ice is used. They switch.the compressor off at full throttle so the power loss is minimized when.it matters. Then the system rechills the water when under lighter loads. The heat capacity of water is large so it just soaks up heat when the load is higher than the dissipation capacity
atypicalguy
atypicalguy
07-19-2015, 08:18 PM #10
Apparently it has been done without the water:
http://forums.hybridz.org/topic/122533-r...?p=1146134
atypicalguy
carlitosgy6
Ranger Turbodiesel
144
08-01-2015, 02:59 PM #11
if the compressor is a gm r4 it swallows 12 hp if its the york 15,i think is not a good idea
carlitosgy6
Edian727
Dreams of 8mm 617
127
08-02-2015, 11:33 AM #12
thinking about it, i think its a good idea to use the water as a heat sink. gives the a/c time to really cool the water, especially if its r134 as it takes a while to actaully build up and be effective. plus then as stated you can kick it off at full throttle and not have the power loss of running the compressor.
if im not mistaken the r12 that you find in the w123 is more efficient then r134 just a lot more toxic. you can still find a few places around my area that'll charge r12 systems.
Edian727
hents99
08-03-2015, 01:28 AM #13
W126 us and japan spec cars have petrol fuel cooling with a/c
hents99
