STD Tuning Engine fits IP-pump from 6cyl 300 td -88 to 300 d 24V -96
countach
09-11-2009, 07:07 AM #1
fits IP-pump from a 6cyl 300 turbo diesel -88 to a 6cyl 300 Diesel 24V -95-96? what differs between them both pumps?
countach
tomnik
09-11-2009, 07:57 AM #2
(09-11-2009, 07:07 AM)countach fits IP-pump from a 6cyl 300 turbo diesel -88 to a 6cyl 300 Diesel 24V -95-96? what differs between them both pumps?
physically yes. The difference is the electronic governor of the 606 IP.
No idea what has to be modified on the 300 D 24 V-car that it will run with the "old" IP. But this has been done.
Tom
tomnik
Tom
countach
09-11-2009, 08:55 AM #3
(09-11-2009, 07:57 AM)tomnik
Tom
what is electronic governor? has 606 engine oil-cooled pistons? was going to put turbo on my 606 24V. and was going to 7mm elements in the IP-pump, and is it better to run with a turbo pump from a 300 Turbo 86 + than to use the pump that sits in 606 24V to modify to 7mm?
countach
Tom
tomnik
09-14-2009, 02:57 AM #4
(09-11-2009, 08:55 AM)countach what is electronic governor?
use the search. The governor is controlled by the engine control box.
(09-11-2009, 08:55 AM)countach has 606 engine oil-cooled pistons?
I believe yes.
(09-11-2009, 08:55 AM)countach was going to put turbo on my 606 24V. and was going to 7mm elements in the IP-pump
How do you do the adjustment of the electronic governor??
This is in progress by some people but no solution as far as I know.
Therefore people use the (mechanical governed) IP out of the 603 and installed larger elements in that IP.
Tom
tomnik
I believe yes.
Tom
Einar
09-15-2009, 03:33 AM #5
The 94-96 OM606 N/A only got electronic controlled idle(ELR), some of the OM603A have this too, or is it differences om the EURO and US engines?
Einar
