STD Tuning Drivetrain Tires
Tires
Tires
EmJay
08-25-2015, 08:51 AM #1
OK so I've had some time to put my new car on the highway.  Boy do I understand the desire for another gear on these 722.3 ATXs!  S, in lieu of finding a 722.5 or 722.6 for my 30 year old sedan, I was wondering 2 things.
#1 what are thoughts of running a larger tire?  Currently with stock size 195/65/14.  Was considering some 205 or 215s to give myself an extra inch or 2 in diameter.
#2 if I do such, how does one adjust the speedo?  IM used to swapping speedo gears on the transmission.
EmJay
Keino
08-25-2015, 10:43 AM #2
No need to adjust your speedometer??
If you switch from your current setup to 205/65 14  the tires rollingcircuit(?) not sure of the proper word, will be 2,13% higher,  215/65 14 will be 4,27% higher.
Atleast in Sweden you are allowed to change this up to 5% from original size tires.
Dunno about the U.S however Huh   Rolleyes
Keino
EmJay
08-25-2015, 11:03 AM #3
I'd like to have a correct speedometer, as future interstate travel is planned. No laws in my area about changing tire size
EmJay
Keino
08-25-2015, 11:22 AM #4
(08-25-2015, 11:03 AM)EmJay I'd like to have a correct speedometer, as future interstate travel is planned.  No laws in my area about changing tire size
Hehe Smile  Well then I can't help you.
I once had my speedo recalibrated, but sent it away to be done by a professional. Maybe someone else knows how to diy? Cool
Keino
08-25-2015, 12:27 PM #5
Yup ... Mine is way way off too with the 2:65 LSD differential and I just added 15" tires. I am going to re-calibrate my face plate on the speedo once I get the engine installed. No way to get a precise speedo cluster if you start changing tires, changing differential gearing, et cet. The customer made plates are cheap and look factory.
EmJay
08-25-2015, 12:47 PM #6
Hmm, so not as simple as swapping speedo gears. Rats. Ah well, my truck still has an inaccurate speedo so what's one more 300K vehicle with a slow speedo?
EmJay
EmJay
08-26-2015, 05:55 AM #7
So no other thoughts about a larger tire?
EmJay
08-26-2015, 07:21 AM #8
In my experience, the old speedos are very optimistic. Have you checked it against GPS? There's likely room increase tire diameter and improve speedo accuracy.
As far as adjusting, I think you can adjust the distance from the cup to the magnet.
EmJay
08-26-2015, 09:45 AM #9
My speedo already reads slow. 75=72GPS
EmJay
08-26-2015, 01:34 PM #10
You're saying an indicated 75mph when you're really doing 72 is reading "slow"?
EmJay
08-26-2015, 07:33 PM #11
Err, I'm going slower than stated. Sorry for confusion. But yes, larger tire may help that. Thanks!
EmJay
08-26-2015, 08:56 PM #12
I'm running 215/55r16 if I remember correctly. Slightly larger than stock, and it actually did help drop my rpm a shade.
I think the extra weight of the tire kind of negates the effects of fuel economy. But then again I went to a heavier rim as well
swampmonkey
hx40 super
280
08-27-2015, 10:43 AM #13
larger tires makes a difference, but not much, i run 195/70r15 in the back of my w123, and had the same on my 240d w115 with a 3.07 differential.
you are talking about your 1985 300d w123 right? how about fitting a 3.07 from a 300tdt aswell as the speedometer, works good on two 72hp 240d manuals i have. (one with a 2.88 and one with a 3.07) so should work without a problem on your automatic 300d 88hp car Smile
that way you will get deacent rpm, and cruising at 60mph is acctualy a pleasure.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
EmJay
08-27-2015, 01:22 PM #14
I thought my 85 had a 2.88 rear? Why would I want a higher gear to lower my RPMs?
EmJay
Petar
7.5mm M pump
459
08-27-2015, 02:57 PM #15
He thought that you have a non turbo 300D  Wink
Keep you diff. Or maybe go with a 2.47 from a W126
Petar
EmJay
08-27-2015, 04:23 PM #16
Never seen a non turbo diesel 300 here before. Guess we like our turbos here in the south, lol
EmJay
Petar
7.5mm M pump
459
08-27-2015, 04:45 PM #17
And i have never seen a turbo w123 myself here in Europe either   Tongue
When you say 300D we automatically assume non turbo.
Petar
08-27-2015, 11:48 PM #18
yes, if your car is a 1985, it's most likely has the 2:88 which is desirable IMO. I think 85 is the only year for the 2:88, except some late production models in 1984. You can check the flange for the stamping. It will hide on you when you look, but once you see the flange, and clean off any crude, it's right there. 3 miles off is not too horrible. mine is off by a bunch ..lol
