STD Other FS / WTB / Buying guides interest in MW65 Holly elements
  • 1 Vote(s) - 5 Average
tomnik
09-15-2009, 01:46 AM #1
Hi,
this is just for my information.
The prototype set of the MW65 Holly elements are on the way to the bench shop to get the swap and adjustment done (takes about two weeks to get bench numbers).
The runtime for fabrication of these elements is quite long.
Now I just try to get an idea of how many sets will follow to avoid doing set after set.
The cost is 75 EUR/piece (barrel+plunger), excl. shipping, made in Germany.
The design will allow to use these elements for stock set up as well as for up to double fuel quantity within the usable range of governor adjustment.
Tom
tomnik
Hi,
Tom
09-15-2009, 01:13 PM #2
Man and I just got an M pump and 6mm elements.
SurfRodder
Jackass Extraordinaire
611
09-15-2009, 02:06 PM #3
Def. still interested brother, I just got a M pump as well, but I will just pull another MW from the yard and go with these instead. I have not yet done anything with the M anyway. I like the idea of leaving it as stock fuel setup and being able to change the IP to deliver more fuel. You were able to do adjustments to increase fueling while the IP is intalled, correct? Anyway, keep us posted!
Josh
OBK# 62
SurfRodder
Josh
OBK# 62
tomnik
09-15-2009, 02:48 PM #4
Whether it is just full load adjustment to 'switch' from stock set up to high performance I have to check when I join the bench guy. But I plan to add the set for external adjustment. The thing is that I have to find the parts that have to be modified at Bosch or just the exchange parts for doing on your own.
The M75 Floyd will follow by middle of October.
Here I just collect potential quantities of elements to get the next run planned.
Tom
tomnik
Tom
SurfRodder
611
09-15-2009, 03:09 PM #5
right on man!
OBK# 62
SurfRodder
right on man!
OBK# 62
tantank79
T3-45
109
09-15-2009, 05:20 PM #6
Provided you can show some numbers, I am interested.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
SurfRodder
611
11-03-2009, 04:04 AM #7
Tom,
any updates on this project? I am definitely interested in these elements and also finishing your full load adjustment mod on my spare pump... anyway, lemme know if you need some funds to get the ball rolling.
Josh
This post was last modified: 11-03-2009, 04:05 AM by SurfRodder.
OBK# 62
SurfRodder
Tom,
Josh
OBK# 62
