Are the w126 - w123 - w116 - w114/115 diff's the same?
Hello guys.
I've read somewhere some of the old mercedes diff's are interchangeable? If so what do you guys think is the best?
Its going to be mounted on a W114 with OM606 and 722.6 E55 AMG gearbox. It must be able to handle some power. However I have very little knowledge about diff's and driveshaft's.
If I have to guess, my best option would be a W126 V8 diff because they probably stronger? with a nice 1:3 ratio? Hoping they have some kind of diff-lock in them? With the matching prop shaft and axles to the wheels. And again, hoping that the axles fit the wheel's lengthwise and with the splines at the wheels. Probably not. The w126 is wider I can imagine.
The car was a w114 200 petrol engine. So I basically don't want to use anything from the original parts. But... if the axles are all the same than I guess I could use those?
Edit: The w114 most powerful engine was a L6 2.8L engine with 185hp. So definably don't want to rely on anything stock.
(01-03-2016, 02:34 PM)Tito Hello guys.
Thank you for your help!
Do you think the 2 driveshafts hold some power? like +500hp? Its suppose to be just a ancient low-power petrol car. They look beefy though....
Playing with the yokes is no problem. I can use a lathe and the E55 AMG gearbox has a 4-bolt pattern instead of a 3-bolt pattern. I need a stronger cardan. The stock petrol cardan is just soooo narrow. It will break I bet.
