OM606
OM606
Hello,
I have one question . From several years I drive w210 with e300td, the car is about 240hp, my question is what flywheel to use for manual gearbox???
Congratulations from Bulgaria !
Hi, it depend which gearbox do you want to use. In my case i use 717.450 and i need to use dual mass flywheel so i mounted 2.2 cdi valeo kit which convert dual mass to single mass.
(01-07-2016, 07:52 AM)soltysrsz Hi, it depend which gearbox do you want to use. In my case i use 717.450 and i need to use dual mass flywheel so i mounted 2.2 cdi valeo kit which convert dual mass to single mass.
(01-08-2016, 02:54 AM)swampmonkey(01-07-2016, 07:52 AM)soltysrsz Hi, it depend which gearbox do you want to use. In my case i use 717.450 and i need to use dual mass flywheel so i mounted 2.2 cdi valeo kit which convert dual mass to single mass.
looking for that flywheel thingy to, got a link where i can find it?
so i buy the right stuff.
did you modify it to fit a larger pressureplate like the sachs765 and sinterclutch? no problem?
Hi,i want to use the gearbox and flywheel from e270cdi (w210).Is it possible that intervention?
Please helpp
