STD Tuning Drivetrain Gearbox Controller 722.6
01-08-2016, 03:38 PM #1
Hello,
Can somebody solution for the fixing ( I thinking about somthin like box) of this controller?
And the number (gearlever) sign can I buy somewere box/frame?
Offroadddieselhu
offroaddieselhu
Hello,
Offroadddieselhu
SurfRodder
Jackass Extraordinaire
611
01-15-2016, 11:51 AM #2
so you're looking for a mounting box for the controller and a gear position indication to install this transmission in another car?
Or are you looking for a full control solution ? I think olefejer has the market on this setup and I think it does have indication of gear select as well.
OBK# 62
SurfRodder
OBK# 62
mcwfxx
01-15-2016, 05:33 PM #3
I re-read, and think you mean like a mounting bezel for the displays?
would be a real simple job for someone with a 3d printer, and i'm sure others would buy them
W639 Vito OM606 + 722.6 STD - in progress
Current progress: engine in, gearbox in, bumper bar modified to accept w210 radiator, audi electric fan, very tight squeeze, interior stripped out ready for new seats (w211) and custom dash with w211 clocks controlled by arduino with split fuel gauge covering main tank and auxiliary for Veg Oil ...
- DSL1 ECU for Electronic OM606 Pump (currently fitting wiring)
Next; 722.6 Controller, HX40 with homemade manifold, Air-to-water intercooler, homemade exhaust, MOT.... One day!
mcwfxx
01-16-2016, 06:45 AM #4
(01-15-2016, 05:33 PM)mcwfxx
Hi,
Yes, I'm looking for that (sory I haven't known that expression)
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
