STD Tuning Engine 1997 OM606 in w210, where to connect turbo gauge
erio
01-17-2016, 01:58 PM #1
Hello
When I had W124 I connected turbo gauge to ALDA.
Where do I connect a 3 way splitter to what vacum line ? or do I have to drill a hole and socket to intake manifold. Is there a rubber hose 2mm diameter with boost going out from intake manifold ?> i cant seem to see it.
I connected in the place of a red dot, but it seams to be negative vaccum not positive turbo pressure.
Dial is going down instead of up.
please advise.
I know the gearbox gets pressure from intake manifold ?
1999 S210 Edc pump. 7.5mm dieselmeken element.
HX35W turbo, custom map.
Brakes 330mm 4 piston brembo CL500, bolt on fit. Longer brake lines. 3mm spacers.
260km/h
2.1 boost for now.
16 inch steel wheels with 20mm spacers.
erio
Hello
please advise.
260km/h
2.1 boost for now.
01-17-2016, 03:09 PM #2
somewhere u have the boost / pressure switch , u can do the 3 ways there.
it is a electric device at the end of a hose coming out the intake piping.
some cal it intercooler pressure pick up.
baldur
Fast
509
01-17-2016, 04:27 PM #3
Just drill and tap the intake plenum or the adapter that bolts to the bottom of the plenum.
Baldur Gislason
baldur
Baldur Gislason
m1tch
01-18-2016, 02:45 AM #4
The pipe where the red dot is a vac/boost line for the MAP sensor - its connected to an output on the pipe just below the plenum, I would still suggest you tap another feed probably on the same pipe as then the MAP boost signal is clean. There is also an intake temp sensor on that pipe which fits into the pipe - you might just be able to repurpose that.
The pipe with the red dot will always be showing vacuum until its under load - the ECU controls the vacuum wastegate (not boost controlled) when it needs, you can't get it to produce boost on idle as the wastegate is 100% open.
m1tch
erio
01-18-2016, 03:06 AM #5
closing topic. It works . I did cut the ruber line where there is red on the picture, and put a 3 way adapter. Than connected it all together with boost gauge. It works. I drove it today amd shows max 15 psi. Stock KKK turbo so far. Will see after i change to HX35 what hapens.
I doubt anything will happen before I remap to use full potential of 6mm elements.
260km/h
2.1 boost for now.
erio
260km/h
2.1 boost for now.
m1tch
01-18-2016, 03:14 AM #6
(01-18-2016, 03:06 AM)erio closing topic. It works . I did cut the ruber line where there is red on the picture, and put a 3 way adapter. Than connected it all together with boost gauge. It works. I drove it today amd shows max 15 psi. Stock KKK  turbo so far. Will see after i change to HX35 what hapens.
Just make sure that there isn't a lag in the boost building with the gauge connected, on mine I found that the extra length of pipework meant a slight lag in the turbo building as the ECU waits for boost before adding more fuel to get more boost.
Also, where did you route the pipework for your gauge?
m1tch
erio
01-18-2016, 03:37 AM #7
I routed it throu firewal under brake "BAS round thing". There is a small ruber plug in a 2cm hole. I poked a hole in it. Then it does over the pedal cluster and to the ashtray.
I belive that if there are no leaks, the pressure inside the tubes will rise almost as fast. This are small diameter tubes. I dont care about 0,2s lag.
260km/h
2.1 boost for now.
erio
260km/h
2.1 boost for now.
m1tch
01-18-2016, 03:45 AM #8
(01-18-2016, 03:37 AM)erio I routed it throu firewal under brake "BAS  round thing". There is a small ruber plug in a 2cm hole. I poked a hole in it. Then it does over the pedal cluster and  to the ashtray.
Thanks for that, will route it through there, when I initially looked at the routing I was amazed at how few grommets there were, also wasn't sure where it would come out or if it was accessible - thanks for confirming, will reroute mine.
m1tch
AlanMcR
mind - blown
400
01-19-2016, 12:47 AM #9
Not to quibble, but on the OM606, the wastegate is pulled closed at idle, if it isn't that tells you that the system is in limp-home mode.
AlanMcR
