STD Tuning Engine Resetting 7.5mm M-pump
scrubs
03-22-2016, 01:04 AM #1
Hi, I'd like to know if there is a way to reset the external ALDA on a M-pump,
I started adjusting and didn't count mark where the original settings of the threaded rods was.
scrubs
50harleyrider
GTA2359VK
397
03-22-2016, 05:19 AM #2
(03-22-2016, 01:04 AM)scrubs Hi, I'd like to know if there is a way to reset the external ALDA on a M-pump,
Is it a Dieselmeken pump? If so send him an email or check utube. He's posted some videos on there for timing the pump. Maybe he has for alda adjustment too.Mine has paint on the threads so if you threaded it out, you should be able to see the original location. If you threaded it in-oh well.
This post was last modified: 03-22-2016, 05:22 AM by 50harleyrider.
50harleyrider
scrubs
03-22-2016, 11:13 PM #3
Thanks, will look again for both
scrubs
