my vw lt recovery truck
That's how it landed in there off the engine crane, I need to move it back and down a few inches, there is a big plastic engine cover in these lt's anyway and the 606 is taller than the 2.4 that it originally came with.
I gave my ecu to TDR to deimmobilize a couple of weeks ago, didn't know you were offering ecus already done at the time
Since I'm using a manual transmission is there a factory flywheel with the 6 trigger pins for the sensor? I can get a flywheel from a 02 c220cdi 6 speed manual but I'm sure I'll need to mod the triggers
Im good friends with TDR Joe is a good lad, he will sort you out,
There was a w210 om606 model with dual mass flywheel , a quick check on ebay shows an luk part
https://infopart.org/luk-415013710-part
this should have your 6 trigger teeth on it.
hard to find an exact image of it though so maybe check with http://www.murfit.ie/ before ordering anything.
i know the c250td are easily got but there obviously a 5 teeth trigger ring
also cdi trigger wheels are 60-1 or there abouts
See the solid flywheel work I did here:
http://www.superturbodiesel.com/std/show...p?tid=5554
Needed a lathe but wasn't hard to put the 6 sensor triggers in.
Wow, that's a brilliant project! Plenty of poke and economical! You just don't see many VW Lt's across here in england, or at least i don't, not the mk1 one anyway, plenty of "sprinters" ;-)
(03-24-2016, 10:02 AM)Ron Good info there thanks. Did you drill the holes to correspond with the pegs on the flex plate is it tdc for each cylinder?Hi Ron,
From the chassis I see - no, only "thin" chassis and vans had wishbones in the front, used on light duty LT28 and LT35 rigs. LT40 and up to LT55 (28 - 2.8T gross weight, 35 - 3.5T...etc.) have thicker chassis and leaf springs.
722.6 really doesn't cut it for a car transporter. Adapter for a stock transmission would be the best option.
I'll have this followed, since I have a friend that drives an LT50 recovery truck that is in dire need of more power...
To answer the earlier question about the sump, I have fitted an e320cdi sump and oil pump, mine is an lt50 so it has leaf spring suspension up front, I think I will need to mod the sump a bit to clear the bar that goes between the wheels as it might hit the sump on full compression
