OM617 NA - Garrett T25 - big enough?
Hi
This engine is in a Gwagen, and it was turbo-ed years ago. I have rebuilt the engine, but unfortunately the turbo is leaking internally.
Before rebuilding the turbo, I want to hear the opinions of Others on whether this turbo is OK for this engine? I realize that there is also the question of what impeller is in there (trim?), but as I will be looking at replacing the impeller/shaft anyway, I would like to know if this is a feasible choice. I never got to drive the car, so have no idea if the original installation worked well or not.
The reason I ask is that the factory OM617A uses a larger T3 - size.
Thanks
Adrian
If anything, you want bigger...
I went small for my NA>turbo conversion and changed my mind - small turbine means high EMP and EGT which will stress the engine more.
Have a read of http://www.4btswaps.com/forum/showthread...nce-Review
Edit: I'll just add, I see no point sticking with 40 year old turbo designs, if that's what you've got. Get something more modern if you can.
(05-26-2016, 04:25 AM)barrote anything from a OEM 3 liter diesel... can do the job... expecially one less than 20 years ago... like the kkk24
