STD Tuning Engine oil feeds
oil feeds
oil feeds
LewisG95
06-29-2016, 06:08 AM #1
Hi,
I am just in the process of getting parts to upgrade the turbo on my 605.
does anyone have any info on the location of the high pressure feed to the turbo? where does it come from and what thread size is it? and does the return just go straight back to the sump?
I am just wanting to get as many things covered as possible to avoid any set backs when the car is in pieces.
Thanks in advance.
LewisG95
Hi,
Thanks in advance.
F.R.A.S
06-29-2016, 06:15 AM #2
m16x1.5 and the feed is on the middle on the block (exhaust side).
Oil return is pretty much under it.
F.R.A.S
LewisG95
06-29-2016, 06:31 AM #3
Thanks man. Smile
Would a 4AN high pressure be adequate enough? or would I be better going a bit bigger? It's for a holset HX27.
Thanks
LewisG95
Thanks man. Smile
Thanks
JVance
06-30-2016, 08:32 PM #4
-3 AN. If you run a -4, I'd consider adding a restrictor.
JVance
