Best place for boost gauge?
That's fine, just place a T in the line, that's how my setup runs. I take it you are not using a boost T/electronic controller and just piping from inlet manifold to the wastegate? If you are using a method of boost control make sure your boost gauge is before the method of boost control, otherwise you will be measuring the "controlled" boost.
Hope this helps
(07-06-2016, 02:45 PM)LewisG95 Ahh okay then that's great![]()
I'm not using any kind of boost controller yet. I could well be in the future though.
Just another quick question... I don't suppose you know the torque and power limit of the auto gearboxes do you?
Thanks for your help.
So I could get my standard 722.6 5 speed to allow upto 1000nm with this standalone controller? Or would there have to be modifications to the gearbox and torque converter too?
I'm not really familiar with auto gearboxes.
I've just had a quick look on the link you sent me though and those controllers with the paddle shift set up do look like a quality bit of kit.
(07-06-2016, 04:35 PM)LewisG95 So I could get my standard 722.6 5 speed to allow upto 1000nm with this standalone controller? Or would there have to be modifications to the gearbox and torque converter too?
Oh right I see.
Sounds a bit of a nightmare with the whole gearbox situation then. The upgrade route that you have taken does seem to pretty wise.
I'm currently only on the standard set up bar a slightly bigger (hx27 from a 3.9 Cummins) turbo and having the ecu chipped. From these two mods I am aiming to get over 200hp and hopefully a little bit more with nitrous. It's good to know the limits of everything before I start going crazy though.
I would love to get mine running that kind of power you're thinking at around 400+ but I do know it is a lot of work and expense and as I say, I just want to see how far I can go and what the limits are of the standard parts.
I suppose my next mods from here would be a different IP and gearbox when I want to go further...
This then leads into another question.. What is the going rate on dieselmeken pumps?
Thanks
(07-06-2016, 07:28 PM)LewisG95 Oh right I see.
Thanks
Thanks
Thanks
Thanks
I've swapped it to a holset hx27 (baby turbo) and just waiting for the ecu to get back now. so I will be able to read boost from the outlet now and get rid of the little vacuum valve thingy now or so I've been told.
I don't know how far I'm wanting to go with it really.. I'm half tempted to go and buy a newish C220 after having a ride in a friends last night. It was so smooth with the torque and ridiculously quiet.
I will see soon though I guess.
