STD Maintenance General Kill switch on 87 om603 300d
bigjoe25
07-06-2016, 01:58 PM #1
Hi guys, seems I have  vacuum leak and the car won't turn off with the key out of the ignition.  I heard there is a kill switch under the hood until I get it fixed, where is it?  It's also nice to know if I had a run-away some day.
Thanks in advance, I've searched and seen mentions of the kill switch but can't find where it is.
bigjoe25
Petar
7.5mm M pump
459
07-06-2016, 02:05 PM #2
It's not really a kill switch, it's a lever on the side of the injection pump, under the intake manifold.It has STOP written on it. This lever pulls the rack to 0 injected fuel quantity.
Petar
bigjoe25
07-06-2016, 04:43 PM #3
Okay thank you, should be easy to find if it says STOP
bigjoe25
