MTDI Bosch VE won't shut off
Hi,
I've build a mechanical Bosch VE pump for a 2.5 R5 TDI. Basepump is a Rover Mechanical TDI pump. Engine runs great, but when i want to shut her off, she keeps running irregular. Pump is tested, nozzels are tested en stopselenoid is tested. All ok. Anybody a idea what's wrong?
the pump should shut off when 12v is taken away from the solenoid. Do you have voltage at the solenoid when it's shutoff?
Any picture of the pump? There are several different styles of VE pumps,
Some I have seen have mechanical stops
The pump makes too high pressure. The distance between the pumping element piston and the "end screw" is too little. increase the distance by installing a thinner shim between the camplate and piston..
That is a very common cause of such problem.
(07-12-2016, 07:54 AM)Evgeniy1987 The pump makes too high pressure. The distance between the pumping element piston and the "end screw" is too little. increase the distance by installing a thinner shim between the camplate and piston..
Wow, not common to see mechanical pump with injection advance selenoid.
