Turbo Choice
Turbo Choice
Hi Lads,
I've been offered this turbo for very reasonable money. These are the specs:
Compressor:
Trim: 55
Inducer Diameter: 50.5 mm
Exducer Diameter: 76 mm
A/R: 0.5
Turbine:
Trim: 73
Inducer Diameter: 65.5 mm
Exducer Diameter: 55.9 mm
A/R: 0.63
Its a T3 flange, so I'd need either an adapter or a new manifold. Its also internal wastegate.
This is going into a 2 ton 4x4, there will be a full 3" exhaust, I'm hoping for 250bhp with the stock electronic pump, and as little lag as possible.
What are peoples opinions.
Too big, too small, cold side too big? any advice is great!
Thanks
Mat
It sounds like it would be good down low, and choke some up top. .63 AR exhaust is pretty small, but if your going to run the stock pump you should be okay I would think.
If it was me I would run it
