STD Tuning Engine Engine maintenance prior to fitting
Chopper746
07-10-2016, 11:40 AM #1
Hi guys,
New to the forum have just got my hands on an om606 i am just wondering if there is anything i should change other than the obvious prior to fitment seals,water pump etc. I will be cleaning and painting it first and looking to run around 350bhp with reliability.
Thanks for any advice.
Chopper746
Hi guys,
zeeman
07-10-2016, 11:45 AM #2
(07-10-2016, 11:40 AM)Chopper746 Hi guys,
Another item to check is the plastic holders that hold the injector lines. They break and the lines rub on the intake. Also the injector return lines. Good idea to replace the glowplugs if it is a high mile engine.
zeeman
Chopper746
07-10-2016, 12:01 PM #3
(07-10-2016, 11:45 AM)zeeman
Thanks for the reply ill put it on the list.
Chopper746
AlanMcR
mind - blown
400
07-11-2016, 01:02 PM #4
The glowplugs in an OM606 should only be replaced when the head is warm. Otherwise they will likely stick in the head and snap off. Then you will be sad.
AlanMcR
