STD Tuning Engine OM606 HX35, since march I dont have good map,
erio
07-27-2016, 02:24 AM #1
Here you can dowload my maps.
 there is:
1. stock
2. ver 1. missing(i didt dowload it from chip  (was 5500rpm max, 27psi boost, little smoke, good map, but after hitting 27 psi went to overboost error, and had to swith of engine for 10 seconds, + intake with MAF is complicated, so I asked to delete MAF. and increase a little bit fueling 2500-3000 rpm,
2. ver 2. from march 2016, MAF deleted, fueling like crazy in low RPM, big clouds of black smoke at any revs from 1000-3000 than air clears, undrivable. Ofcourse after hitting 25 psi goes to no boost at all.
3. I left the car at mechanic for 2 weeks. He came up with 3rd map, that most of the time doesnt work, sometimes kicks in during driving. told me to fool mapsensor with manual boost control, (after idea with 0-4 atm mapsensor from VW didnt work)
4. Map from internet , probably requires MAF , undrivable, but on my way on highway, used to kick in (MAF is installed low near bumper level to catch some air flow. I drove 180 km without overboost error, it was off everytime i slowed down, but power kicked in after cople of seconds of 100% throttle, very deleyed power response, probably because of MAF in bumper instead of intake.
[/url]
https://drive.google.com/file/d/0B4eNTM_gCM5ZN1JqMmtydHpuZms/view?usp=sharing
this are my maps.
I have a 1998 300TD , with Electronic pump, HX35 turbo, and sockets soldierd to my ECU board.No EGR, NO catalist
I have the WG valve  always vaccum possition, (baypass to provide vaccum to WG valve, to keep iWG closed at all time, when I connect it properly thru valve , WG does not shut, computer does not send valve signal to let  vaccum thru since the time we we changed the turbo( before turbo upgrade stock ar worked perfectly) , so I baypassed it), I have also a Map sensor from VW 0-3 bar atm (up to 2 bar boost). When I drive on soft ver 1. and ver 2, I keep getting overboost error and I have to shut engine off for 10 seconds, and restart. And it smokes alot (ver 2. ). In ver 2 MAF is supposedly deleted. Its not installed at all before turbo. I dont have intake , I want a K&N directly on turbo. I asked my guy to delete form soft MAF starting ver 2. Dont know ver 3, never worked, maybe because of missing MAF in intake.
since March 2016 when I payed the guy to put sockts on ECU, and remap chips, he couldnt supply me with stable soft that does not get errors and once works, and once does not.
ver 1 was once working boost up to 27 psi, and not working via overboost, I purchased mapsensor 4 bar(3bar boost), and tried it on , but with it connected there was permanent mapsensor error (0,9V on ignition, mapsensor linearisation wrong, or something, noone i know can find and change linearisation map of mapsensor volts/airpressure) but it operates in other volt range (instead of 1,6V on ignition, its lower) and ECU puts default constant pressure readout at 1024hPa when 0,9V error detected.
For now I know that when car runs with boost, its capable of 26 psi of boost, and 260km/h topspeed,
The best soft is probably the one a friend dowloaded from internet in july(no overboost issue, and having to switch of engine for 10 seconds)), but I have to run it with properly connected Airflowmass meter, before turbo with proper intake, I would prefer to delete it from map, as long as there will be no big smoking because of lack of it.
But it should be possble to limit smoke based on mapsensor, and boost readout ?
any suggestions welcome.
The guy that was payed to write me a map, is not answering phone ... and I am to stupid to modify winols without any help
in the future I was thinking of replacing elements to 7,5mm, and getting in this pump, but looks like i will have to change gearbox to manual, and put mechanical pump ? unless I find help.
erio[Image: new_user.png] Posts: 1Joined: Tue Jul 26, 2016 10:35 pmLocation: Kielce, PL
  • [url=http://www.ecuedit.com/ucp.php?i=pm&mode=compose&action=quotepost&p=46842]
This post was last modified: 07-27-2016, 02:36 AM by erio.
1999 S210 Edc pump. 7.5mm dieselmeken element.
HX35W turbo, custom map.
Brakes 330mm 4 piston brembo CL500, bolt on fit. Longer brake lines. 3mm spacers.
260km/h
2.1 boost for now.
16 inch steel wheels with 20mm spacers.
erio
 there is:
1. stock
[/url]
this are my maps.
260km/h
2.1 boost for now.
starynovy
07-27-2016, 03:25 AM #2
Doing smoke control only by MAP is completely normal, many cars of this era had it this way and did not smoked a bit. Airmass is given by temperature of air and volume of cylinder and absolute pressure, MAF is not needed unless you want to monitor EGR of course.  Big Grin
starynovy
50harleyrider
GTA2359VK
397
07-27-2016, 04:36 AM #3
What manifold do you have the HX-35 mounted on? Are you monitoring EGT?
50harleyrider
50harleyrider
GTA2359VK
397
07-27-2016, 04:38 AM #4
What manifold do you have the HX-35 mounted on? Are you monitoring EGT? You can send your e-pump to Dieselmeken for elements. Also consider Baldurs' ecu. From what I've gathered that's the way to go for performance from e-pump.
This post was last modified: 07-27-2016, 04:40 AM by 50harleyrider.
50harleyrider
erio
07-27-2016, 04:50 AM #5
(07-27-2016, 04:38 AM)50harleyrider What manifold do you have the HX-35 mounted on? Are you monitoring EGT? You can send your e-pump to Dieselmeken for elements.
I have an adapter made from 1 om606 plate, one 90 deg. pipe and 1 HX35 plate.
http://i1250.photobucket.com/albums/hh52.../photo.jpg
No I dont monitor EGT, on stock element I dont expect EGT to be big issue (I have valvoline VR1 race motoroil, reving rearly to 5500 (automatic gearbox changes at 4800 usualy). Untill i upgrade elements, i dont need to monitor EGT.
I hope to make 90ccm of fuel on this 6mm element, and boost is unlimited but doesnt go beyond than 27 psi. (2 bar)
As I understand it correctly, if I have more air than fuel, and I dont make much blacksmoke (at 3000-5500rpm), EGT shoulndt be out of control, and with this setup I will always have more air than fuel.
Regarding Dieselmeken and his elements,  first I want to have a map that ALWAYS uses this 6mm element, and gives 100ccm fuel, use all rack travel, give 4,6V on pump, ... than Iwill think about updating. (Is it possible to have a volt meter installed on cable to Injection Pump ? to monitor if computer gives 4,6V for max rack travel ??
I already had pleasure of owning and driving HX35 on  OM603 in W124 with dieselmekens 7,5mm elements, and it was doing 80-180 in 11-12 seconds.
This post was last modified: 07-27-2016, 04:55 AM by erio.
260km/h
2.1 boost for now.
erio
260km/h
2.1 boost for now.
seanyt
is300d He351ve
279
07-27-2016, 05:43 AM #6
Do you have the ability to program chips yourself?
Are you using the stock 6mm pump?
This post was last modified: 07-27-2016, 05:43 AM by seanyt.
seanyt
50harleyrider
GTA2359VK
397
07-27-2016, 07:03 AM #7
That looks similar to adapter I bought from Hario on here. I haven't had a chance to use it yet. Curious if you have any other support on the turbo for bracing? An ecu from Baldur not interest you especially since you want to use e-pump? You should at least PM him-good guy.
This post was last modified: 07-27-2016, 07:05 AM by 50harleyrider.
50harleyrider
erio
07-27-2016, 07:26 AM #8
(07-27-2016, 05:43 AM)seanyt Do you have the ability to program chips yourself?
Yes. I have an old programator for parallel port . I can read and write 32 pin memory myself.
Yes the pump is unmodified stock. Just trying to max it out.
I tried to find onwilOLS this maps
Maps in first codeblocks :
voltage 3D8D4
torque 3CF04 (20X1) ??
smoke 3D004
driver wish 3A000 ??
3AF7E would be EGR,
3CAB8 would be cranking IQ
3E7C0 would be requested boost
3EBA0 would be atmospheric pressure boost limiter
3E4B2 IQ limit fct t° - cant really get what this is, it something but the temperature is quite odd.
but I cannot find it in any of both files at this addresses, I must be doing something wrong.
I would like the engine not to stop giving fue lwhen 2 bar is reached
This post was last modified: 07-27-2016, 07:36 AM by erio.
260km/h
2.1 boost for now.
erio
voltage 3D8D4
smoke 3D004
3AF7E would be EGR,
260km/h
2.1 boost for now.
erio
07-27-2016, 02:25 PM #9
[quote pid='82160' dateline='1469622401']
[/quote]
Thank you,  seanyt
No limp mode. No overboost problem. Constant 27psi.
Its a map for earlier spooling turbo and other elements, so will need adjustments.
Ps. First part of video is uphill Smile
https://youtu.be/8LWg4-k55NY
260km/h
2.1 boost for now.
erio
[/quote]
Thank you,  seanyt
260km/h
2.1 boost for now.
starynovy
07-27-2016, 04:40 PM #10
Well, well 2Bar.. I have to modify my old GT25C on OM605.. never got around that boost control on this shit ECU. Will fit pressure operated WG and run it like that.
starynovy
50harleyrider
GTA2359VK
397
07-28-2016, 06:53 AM #11
Bump Baldur. Why not? With his ecu ,you can program with a PC! No chip mods required and you'll get rid of that crappy oe ecu and you can play with your e-pump all you want! That's my intent on my F150 swap.
This post was last modified: 07-28-2016, 06:58 AM by 50harleyrider.
50harleyrider
seanyt
is300d He351ve
279
07-28-2016, 07:12 AM #12
he has already spent money on his ecu getting it modded, and has a chip programmer.
No point going to the added expense of a new ecu and wiring the complete unit in and wiring in clocks etc.
Baldurs ecu is great for engine swaps into other vehicles and edc pump extreme tuning.
Most of the time a remap and 8mm pump does people without the need to go changing parameters.
Ive remapped plenty of different kinds of ecus, most people just want a working solution not added expense or work.
seanyt
50harleyrider
GTA2359VK
397
08-02-2016, 05:10 AM #13
The architecture of the oe ecu doesn't lend itself well to chip tuning. I wish Baldur would pipe in.
50harleyrider
baldur
Fast
511
08-02-2016, 06:29 AM #14
I don't think the architecture of the oe ecu would lend itself worse to chip tuning than most other oe ecus. In fact it's not a very complicated system compared to most other oe ecus, it only controls a couple of outputs that are of any significance.
The oe ecu is just like most other oe ecus in one fact, there's hardly any information about its maps or control strategies publically available or on the open market. This means that a person who just wants to tune their car to their satisfaction cannot just go and buy something like hptuners/binary editor/tunercats/hondata and start tuning.
They'll have to either spend countless hours reverse engineering or find someone who has done that and documented their work to the extent that it is of any value and they're willing to sell it. (if that person even exists)
Tuning is not supposed to be a dark art, but when dealing with a system that isn't documented at all and the original author can not be reached for comment, it always is a kind of a dark art (and this applies to even the most popular OEM reflash solutions, the software vendors didn't make the ECUs and only know half the story behind all the countless maps and the strategies that connect them).
Now, if your setup is not highly modified and not modified in an unusual manner, you can get chips with programming that is known to work, and this is an easy solution if you have a running car and just want more performance out of a pretty much standard package.
Baldur Gislason
baldur
Baldur Gislason
seanyt
is300d He351ve
279
08-02-2016, 06:39 AM #15
Couldnt have put it better myself baldur.
seanyt
Suitko
W210 OM606
7
08-05-2016, 04:55 PM #16
Hey Erio, what is the size of exhaust housing on your hx35?
Thanks Wink
Suitko
Thanks Wink
Spoolin
09-08-2016, 10:55 AM #17
I would be interested in a similar program for my 98 e300td.  I have plenty of spare turbos laying around and can socket the ecu locally if someone is willing to sale me a chip.
Any idea how much power the hx35 is making with 27psi and stock pump?  I have been searching for days and I see the number 250hp thrown around alot.  If you are making 2bar on stock pump I would assume you are fueling enough to make over 300hp.
Thanks,
Bryan
Spoolinawd@gmail.com
Spoolin
Thanks,
Bryan
50harleyrider
GTA2359VK
397
09-08-2016, 11:34 AM #18
(08-05-2016, 04:55 PM)Suitko Hey Erio, what is the size of exhaust housing on your hx35?
Thanks Wink
I'd like to know also. Now that I'm planning to use the e-pump with Baldurs' ecu, will my HX-35 w 10cm turbine housing be viable? Seems like turbo selection is infinite. Hopefully enough folks will report results of their particular selection. Erio, can you post a photo of the HX-35 installed. Any bracing?
This post was last modified: 09-08-2016, 11:40 AM by 50harleyrider.
50harleyrider
Thanks Wink
seanyt
is300d He351ve
279
09-08-2016, 02:48 PM #19
(09-08-2016, 10:55 AM)Spoolin I would be interested in a similar program for my 98 e300td.  I have plenty of spare turbos laying around and can socket the ecu locally if someone is willing to sale me a chip.
Thanks,
Bryan
I can email you maps to try if your ecu is socketed and you have programmable chips. Stock ecu can only see 1.7bar boost so 250hp is a low smoke max. It will do more but long injection events increase egt.
The larger pump elements get more fuel in sooner and result in lower egt.
The only other solution is to increase the rev limit to get more HP . Now my new turbo is fitted I'll be dynoing soon and testing new rev limits.
seanyt
Thanks,
Bryan
Spoolin
09-08-2016, 06:16 PM #20
I understand power is limited with stock pump due to element size.  Couldn't the ecu be tricked with a map clamp to limit voltage so it thinks the boost is less.  An even easier way is to bleed pressure from the sensor to the atmosphere.
When programming the chips I figure the max boost pressure limit would be deleted just as you would delete egr function and the maf sensor.
Spoolin
seanyt
is300d He351ve
279
09-09-2016, 01:58 AM #21
If the ecu sees less boost it fuels less.
A remap removes egr / airflow meter and boost limits.
So you can run any boost setting but 1.7 is the map sensor limit.
Also you can run more boost to keep heat down. It's just not advised to run a 6mm at its limit.
It's safer to run an 7.5-8mm pump at the same fuel setting for the same power and headroom for more.
But it depends what your goal is. Happy with 250hp 6mm anymore start considering swapping elements. This goes for om605
seanyt
Spoolin
09-09-2016, 05:30 AM #22
Is the programming the same? I have an om606. Guess that means it's capable of more power than the 605.
Spoolin
seanyt
is300d He351ve
279
09-09-2016, 06:53 AM #23
i have maps for both engines.
om606 will go to 300hp but same goes any more and youll want bigger elements to get safe power.
seanyt
