STD Maintenance General lost center blowers and automatic windows
LewisG95
08-03-2016, 08:50 AM #1
Hi,
I have recently just lost use of my automatic window switches and center blowers. The passenger and drivers blowers still work and my windows do still work but just don't have the automatic mode.
I have checked all fuses and they all seem to be okay.
could this be a relay?
Any help would be much appreciated.
Thanks.
LewisG95
Hi,
Thanks.
EmJay
08-03-2016, 09:47 PM #2
And the car is???
EmJay
And the car is???
bricktron
'77 240D
174
08-12-2016, 11:33 PM #3
without knowing what car this is: if those things are on the same circuit, the problem is likely to be at the fuse or the fuse contacts (see if you can clean them off). if not, they are two separate problems that happened to occur near to each other in time.
bricktron
