Need longer driveshaft
My OM603 powered s123 needs a driveshaft I don't have. I was planning on using the stock one (1983 300TD) but it's about two inches too short (even when extending it). The one I pulled from the parts car (1987 300TD) is too long, about 1/2" when fully compressed.
Does anyone know if the front half of an SD (w126) driveshaft is longer than the D (w123)? Could I swap out the front section and get it balanced?
I'd rather not machine down the 87 driveshaft if I can get away it with as the center carrier is in a different position (i.e. needs fabrication to work).
