STD Tuning Engine 606 Oil Cooler
606 Oil Cooler
606 Oil Cooler
matfield
09-08-2016, 02:44 PM #1
Lads,
How does the 606 cope without an oil cooler, is it essential, recommended or overkill for stock power and turbo?
Thanks
Mat
matfield
Lads,
Thanks
Mat
baldur
Fast
511
09-08-2016, 03:20 PM #2
Depends on your application. I've found that driving my Musso truck around at moderate speeds (<100km/h) it never even opens the oil thermostat, oil cooler stays ice cold.
The situation where you need an oil cooler is prolonged operation at high loads and high engine speeds, ie going fast on the motorway or towing.
Baldur Gislason
baldur
Baldur Gislason
matfield
09-08-2016, 03:23 PM #3
Ok... Is there a way of monitoring the Oil thermostat with the DSL1? or Oil temp?
This post was last modified: 09-08-2016, 03:23 PM by matfield.
matfield
baldur
Fast
511
09-08-2016, 03:31 PM #4
You can hook up an oil temp sensor, but unless you're looking to log it it's easier to just fit a gauge to monitor it.
Baldur Gislason
baldur
Baldur Gislason
matfield
09-08-2016, 03:35 PM #5
Thanks
matfield
Thanks
