STD Tuning Engine Highest hp OM613
Highest hp OM613
Highest hp OM613
baldur
Fast
511
09-23-2016, 09:19 AM #1
What's the highest known power output from an OM613? Doesn't look like there's many people tuning those at the moment.
I recently picked up a W210 E320 CDI and I've got no plans but want to see if I can make it a little better.
Baldur Gislason
baldur
Baldur Gislason
starynovy
09-23-2016, 10:04 AM #2
It will do 180-190kW "as-is". Then first bottleneck are small injectors and CP1 which will not support greater power anyway. I have upgraded C30CDI injectors and CP3-L110 pump, it burns cleanly around 125mm3 so my guessing is that it makes 220-240kW. Could go much higher but GB will fall apart. Anyway look at Blacksmoke OM648 compound build. They had 500+HP and mechanically it is exactly the same engine except it is working on higher rail pressure from factory.
starynovy
baldur
Fast
511
09-23-2016, 01:03 PM #3
Quote:Could go much higher but GB will fall apart.
What's GB?
Baldur Gislason
baldur
What's GB?
Baldur Gislason
starynovy
09-23-2016, 04:23 PM #4
Gear box.. it is W580 hence made for maximum of 580. It is reported to hold more but for how long and it is not new.. so you would have to strenghten it or mount one from S600 biturbo which will withstand 1000Nm just fine.
starynovy
baldur
Fast
511
09-23-2016, 05:33 PM #5
Ah, mine has a 722.6.
Baldur Gislason
baldur
Baldur Gislason
R-3350
Dreaming of compounds
182
09-23-2016, 09:41 PM #6
the 722.6 comes in many different ratings the w580 means its rated to hold 580NM of torque. the highest rated ones are from some amg and s600 models they're rated at 1000NM
R-3350
Evgeniy1987
09-24-2016, 05:37 PM #7
722.6xx is also called w5a380, w5a580 or w5a900 .
What you can do is indeed like the guys say: take the most beefy gearbox, but then swap the bellhousings, because of the different bolt patterns.
Evgeniy1987
baldur
Fast
511
09-24-2016, 07:38 PM #8
Does the OM613 use the same bellhousing as the OM60x engines?
Baldur Gislason
baldur
Baldur Gislason
Dieselsec
09-25-2016, 05:01 PM #9
(09-24-2016, 07:38 PM)baldur Does the OM613 use the same bellhousing as the OM60x engines?
No the bell housing for the om613 is different to the om606 . It  looks similar but is a larger diameter and as such     uses  different diameter flexplate
W116 om611
Dieselsec
W116 om611
erx
w202 om606
323
09-25-2016, 05:27 PM #10
OM613 and OM648 have unique bellhousing, as fas as I know no other engine uses this pattern.
This post was last modified: 09-25-2016, 05:27 PM by erx.
erx
