Dimensions 722.6
Is there a difference in dimensions of my 330Nm gearbox and the stronger ones? Does a 722.6xx fit in the trunk of my E300 w210 sedan?
Dimensions are the same but there are different bellhousing bolt patterns. You can fit many of them in the trunk.
I know the boltpattern is different. Needed to know if i can testfit the 300td gearbox before buying a new one. Thanks
