STD Tuning Engine om605 block
om605 block
om605 block
Antonio
12-29-2016, 10:32 AM #1
hey folks...
anyone knows if om605 2.5td engine got some sort of cousin? i have heard that the 2.9l block is the same? is that true?
Antonio
hey folks...
12-29-2016, 12:20 PM #2
No, not in my knowledge.
Although the 2.9 liter OM662 is based in the 602. and the OM602.98X 2.9ltr DI is based on the 602 it is even 2 valve.
The 605 block can be drilled to 89mm bores and then.... there is no pistons to use with the 4 valve pockets and the same diameter wrist pin.
dadadada....
dadadada....
