STD Tuning Engine Delete clutch fan?
Delete clutch fan?
Delete clutch fan?
BoostedW124
02-13-2017, 07:44 AM #1
I'm doing away with the belt driven cooling fan to replace with electric.  My question is do I still need to run the pulley to spin the waterpump or is it driven internally?
BoostedW124
02-13-2017, 07:47 AM #2
Yep...
Yep...
AlanMcR
mind - blown
400
02-13-2017, 02:36 PM #3
Yep... you still need to run the waterpump from the belt, also the alternator.
I experimented for a while with electric fans. Eventually I switched back to the fluid clutch operated fan.
AlanMcR
baldur
Fast
511
02-14-2017, 06:27 AM #4
You can also run an electric water pump.
Baldur Gislason
baldur
Baldur Gislason
charlysays
02-14-2017, 06:56 AM #5
The viscous fan on the OM605/606 does the bulk of the cooling. You'll need a very decent electric fan to match it. Also the viscous fan is pretty reliable- even when the clutch is worn it still cools fairly well.
charlysays
BoostedW124
02-14-2017, 09:55 PM #6
Ok Thanks. I'll try an electric fan in place of the viscous and put the 2 factory ones on the other side of the radiator. Must help getting rid of the ac condenser blocking the radiator. I would guess that disrupts efficiency quite a it.
BoostedW124
BoostedW124
02-14-2017, 09:56 PM #7
Quite a bit*
BoostedW124
Quite a bit*
02-17-2017, 01:15 PM #8
IT does, but we all fit a 2" core intercooler which does more blocking..
zeeman
02-17-2017, 02:30 PM #9
(02-17-2017, 01:15 PM)Hario IT does, but we all fit a 2" core intercooler which does more blocking..
I guess the question would be is why you are eliminating the factory fan. Do you have a cooling issue. The factory fan and shroud should be more than enough to cool.
zeeman
BoostedW124
02-20-2017, 10:14 PM #10
Reason being is I'm swapping the 606 into a 190e and the fitment is tight. I hope the e fan will be adequate. ..
BoostedW124
02-21-2017, 03:29 PM #11
(02-20-2017, 10:14 PM)BoostedW124 Reason being is I'm swapping the 606 into a 190e and the fitment is tight. I hope the e fan will be adequate. ..
190 2.6 radiator has a pair of PACET or SPAL fans which are 2" thick, which is what most use for 606 into 190, along with 2.6 rad, though which I think would be too small IMHO
hooblah
02-21-2017, 04:59 PM #12
Actually, 2.6 rad seems like the perfect size but I'm finding it too tall (for my setup at least). Where did you hear that it wasn't adequate?
This post was last modified: 02-21-2017, 04:59 PM by hooblah.
hooblah
