STD Other Projects W210 EDC pump. Connect voltage meter to rack position sensor
erio
03-01-2017, 11:47 AM #1
Dear friends
I have a boost gauge to measure the amoint of boost.
Is it possicle to connect (tap on) the electric cable goint to EDC pump, to see the voltage coming out of tack travel sensor? I would find it usefull to know what is the voltage on rack position sensor. If its 4.5V i would be sure that the fueling is 100% according to the map. And that the engine simply runs on 100% fuelong available.
What do you think?
Is there a better place to tap in near ECU? Any clue what cables colors to tap in? Will it compromise computer signals? A small voltometer in cabin?
1999 S210 Edc pump. 7.5mm dieselmeken element.
HX35W turbo, custom map.
Brakes 330mm 4 piston brembo CL500, bolt on fit. Longer brake lines. 3mm spacers.
260km/h
2.1 boost for now.
16 inch steel wheels with 20mm spacers.
erio
Dear friends
What do you think?
260km/h
2.1 boost for now.
starynovy
03-01-2017, 12:43 PM #2
It is not since on HDK rack sensor there is HF sinewave and at the rack coil itself there is rectangular PWM signal.. well multimeter will measure something there but it will surely not correspond with voltage map in the ECU. Better is to use live-data diagnosis but these old diesels require STAR to see this.
starynovy
seanyt
is300d He351ve
279
03-01-2017, 01:35 PM #3
starynovy nailed it there.
The CC212/5 chip that controls the rack position, outputs an analogue and digital signal and these represent the rack position to the microprocessor.
When you measure the signals at the rack position, you are measuring an AC signal so any multimeter will just show RMS of this in DC.
your map is scaled to 4.0-4.1V
there is more but it will begin to get smokey on boost. unless you plan on running 3bar.
seanyt
erio
03-06-2017, 12:04 AM #4
I plan on running unlimited boost Smile
My WG is forced closed, giving 2.1 bar boost on you map sir.
But i didnt buy a 3 bar boost gauge for nothing Smile i had 1.9 boost on stock elemects in stock pump. I had   (27psi) on remapped 6mm element 260km/h. I would like to have 4.5v and full rack travel  and see how much boost my stock manifold with adapter can deliver.
The mapsensor is a 3 bar audi. And i saw my pump give 16cm fuel on 100 strokes when it was on the bench.
I belive i have tturbo big enough to 3 bar, and fueling 160ccm/1000strokes at 4.5v.
I relaise that above 2.2 boost i will be putting my headgasket at danger. I have a spare engine Smile
I want to see more boost. Smoke disaperas on full throtttke around 4500rpm.
Can you pease send me a map that 4500-5500 gives 4.5v?
Call it crazyass headgasket killer LL & HH Smile
This post was last modified: 03-06-2017, 03:57 AM by erio.
260km/h
2.1 boost for now.
erio
260km/h
2.1 boost for now.
seanyt
is300d He351ve
279
03-06-2017, 04:44 AM #5
i can happily send you a map to max the rack voltage but you where having issues with that turbo at 6k so raising the fuelling is going to introduce that problem lower in the rev range.
When i get a chance ill send you a revised map, but be warned your into hx40 territory now.
" crazyass headgasket killer LL & HH Smile  " haha
This post was last modified: 03-06-2017, 04:44 AM by seanyt.
seanyt
Phil O' Dendron
05-01-2017, 01:16 PM #6
Quote:s it possicle to connect (tap on) the electric cable goint to EDC pump, to see the voltage coming out of tack travel sensor?
Hi erio,
you could measure the actuator signal with an Arduino board, as the frequency of the rectangle signal is only 40Hz.
I tried to do this, but lost my mojo when the car failed annual inspection because of massive rust, and gave the arduino away, too.
There are code snippets for a "frequency counter" or "Frequenzzähler" (found it on a German board) that are good to start with.
Measure the "hi" pulse length, divide by a complete cycle length (should be around 1/40 seconds),
multiply with the pulse amplitude (should be something between 13 and 14.4 volts, depending on your battery charge state),
et voilá, you got the equivalent DC voltage.
I bought a C 250 TD again, will give this a new try, but not in the next few days.
cheers, phil.
___________________________
1996 vito 108d w638 om601 n/a
1996 c250 tdt s202 om605.960
Phil O' Dendron
Hi erio,
cheers, phil.
