STD Tuning Engine Air filter cfm, do i have enough?
scrubs
04-04-2017, 11:10 AM #1
Hi, a common question but no solid answer.
Om617, 7.5mm m-pump, 315 injectors, 60mm Garrett turbo, full width bar intercooler.
Current air filter is a Jaguar canister with a EAC 9828 WIX equivalent with a ram air snorkel system from roof area.
I cannot find any cfm for this filter and would like to know if the engine is getting enough cfm to run properly,it runs fine but just making sure.
No not interested in the cone filter but maybe a Donaldson of correct cfm's for improvement for sure.
Input greatly appreciated
scrubs
baldur
Fast
509
04-04-2017, 12:02 PM #2
Fit a filter minder, it's the only way to be sure, and only way to know when the filter needs replacement too. They are these little vacuum gauges found on the air filter of pickup trucks and machinery. They record the highest amount of vacuum seen and tend to bottom out around 5-6kpa of depression. Then you press a button to reset the reading.
They can be had for just a few bucks on eBay.
[Image: 2017_02_10_23_04_13.sized.jpg]
This post was last modified: 04-04-2017, 12:04 PM by baldur.
Baldur Gislason
baldur
Baldur Gislason
04-04-2017, 12:07 PM #3
^^ Service trucks (F350, anything with a box body, etc.) in the junyard usually have them too.
TurboTim
04-04-2017, 12:14 PM #4
Yeah best answer is just to find out yourself and see if there is any vacuum in the feed between filter and turbo.
76 300TD custom lots of stuff
TurboTim
scrubs
04-05-2017, 09:08 AM #5
Ok Thanks for replys.
Found out the cfm of this filter to be 305.
Figured 400cfm was needed from some posts read
scrubs
