STD Tuning Engine 606 Transition Pipes
04-17-2017, 11:00 PM #1
How much would y'all pay for these badboys in mild steel? in stainless?
606 exhaust oval -> 2" ID pipe.
Trying to judge if it's worth the time to makeup a die set.
04-18-2017, 05:53 AM #2
From experience I would say 1.5" outlet would be easier to fabricate a manifold from with the space available, but to answer your question I would have bought a set off you if these were available 6 months ago!
Beers
Beers
04-18-2017, 11:40 AM #3
2" is on the big side. Unnecessary internal volume isn't good on a turbo manifold. Also transitioning to a divided T3 would be murder.
04-18-2017, 12:00 PM #4
The circumference of the 606 outlets is the same as a 2.25" pipe, It would be interesting to stretch out a 1.5" pipe to 2.25"....
04-18-2017, 01:44 PM #5
First test with the prototype die, using 2.25" exhaust pipe (1/16" wall, has a 2.125" ID)
I didn't center it properly and mangled the round end, but the oval came out pretty nice.  It was a TIGHT fit with the 2.125" pipe, 2" thick wall is going to be a bear!
baldur
Fast
511
04-18-2017, 06:59 PM #6
Nice work
Baldur Gislason
baldur
Nice work
Baldur Gislason
04-19-2017, 09:50 AM #7
[/url]
(04-18-2017, 12:00 PM)Simpler=Better The circumference of the 606 outlets is the same as a 2.25" pipe, It would be interesting to stretch out a 1.5" pipe to 2.25"....
Why not just make it from 1.5" to 2.25" concentric reducers like everyone else?
[url=http://s1250.photobucket.com/user/Mercedes_Power/media/concentric%20adapters.jpg.html][Image: concentric%20adapters.jpg]
This post was last modified: 04-19-2017, 09:50 AM by Hario'.
[/url]
04-19-2017, 10:05 AM #8
Where the heck are you getting those?  Stateside I've only been able to find cast reducers.
This post was last modified: 04-19-2017, 10:09 AM by Simpler=Better.
hooblah
04-21-2017, 03:03 PM #10
Looks good! I'd definitely be up for buying a set.
1/16" wall sounds a bit thin, no? Probably better off with 1/8".
My only issue with those concentric reducers as Harry mentioned is that they appear quite long, which could be a negative for those with space constraints. If they were shorter I'd go for them.
hooblah
04-25-2017, 12:12 PM #11
Smushed up a 2" sched40 pipe the other day(It still needs finishing, but this is the general idea)
1.5" will follow(or explode) soon....
04-26-2017, 03:19 PM #12
So yeah, 1.5" schedule 40 wasn't too happy:
04-27-2017, 07:33 AM #13
(04-19-2017, 10:05 AM)Simpler=Better Where the heck are you getting those?  Stateside I've only been able to find cast reducers.
Lol they are 'weld-els', more formally weld elbows, very easy to find in USA very hard to find in UK...
They are cast steel so they bent well.
I used 2.25" x 1.5" concentric reducers and they are perfect, just trimmed them down a bit because full size they stick out from the manifold flange about 4" and we have steering box on RHD. I would suggest you try the same,
04-27-2017, 10:36 AM #14
(04-27-2017, 07:33 AM)Hario\
Finally found a local source, they're like $$ though.
TurboTim
05-01-2017, 07:59 PM #15
Ace stainless has the concentrics that I used. I have a bunch of extra flanges if anyone wants them. I have stainless and mild steel.
76 300TD custom lots of stuff
TurboTim
05-02-2017, 11:17 AM #16
I found local reducers, but the damn things are like $20/pop.  Pressed really nicely though:
05-17-2017, 01:43 PM #17
Awwwww yeahhhhhh
[Image: 2n033ud.jpg]
This post was last modified: 05-17-2017, 01:49 PM by Simpler=Better.
Awwwww yeahhhhhh
TIMNZ
05-17-2017, 05:26 PM #18
Looking good, regarding the conc reducer size I presume you mean 2.5" x 1.5" or for those of us that use Metric  65 x 40 .
Cheers
Tim
TIMNZ
Cheers
Tim
05-17-2017, 09:47 PM #19
(05-17-2017, 05:26 PM)TIMNZ Looking good, regarding the conc reducer size I presume you mean 2.5" x 1.5" or for those of us that use Metric  65 x 40 .
Cheers
Tim
Nope, 2.0" x 1.5" aka 51mm x 38mm.  The die stretches them out all right, I want to say somewhere around 1/5 to 1/4 load on the gauge (It's marked as a 50 ton press, so I assume around 10tons of pressure?
That set's headed to a customer in FL, once I get some free time (haha) I'll be making another two sets.
Cheers
Tim
05-18-2017, 08:22 AM #20
baldur
Fast
511
05-18-2017, 10:05 AM #21
A lot of work, but the outcome is beautiful.
Baldur Gislason
baldur
Baldur Gislason
CRD4x4
CompoundSuperTurboDiesel4x4!
399
05-18-2017, 11:00 AM #22
(05-18-2017, 10:05 AM)baldur A lot of work, but the outcome is beautiful.
×2!  Heart
You might have to charge a bit more for these bad hombres! Except for mine of course.
CRD4x4
×2!  Heart
Bigpanda16
05-24-2017, 01:54 PM #23
Nice looking work for sure, far quicker than cutting/welding 3 deep well 1/2" sockets together and shop pressing them into shape.
Curious what would it take for a set of 6 like so?
78 300D, 87 190D, 94 E320, 95 E300D
Bigpanda16
05-30-2017, 02:31 PM #24
I'm thinking that $30/pop ($180/set) for fully machined ready-to-weld covers my time.
That being said, I'm completely overwhelmed at the moment (main car & backup car are both down for the count)
Mallinman
04-12-2018, 06:05 AM #25
When you guys are using 1.5" pipe for you manifold tubes do you mean 1.5" ID or OD??
The 1.5" ID pipe that I have looks massive and wondered if it would affect the pressure. I know it would help top end flow but it would bugger the low rev spool up.
This post was last modified: 04-12-2018, 06:05 AM by Mallinman.
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
baldur
Fast
511
04-12-2018, 06:14 AM #26
(04-12-2018, 06:05 AM)Mallinman When you guys are using 1.5" pipe for you manifold tubes do you mean 1.5" ID or OD??
He likely means 1.5" schedule 10 or 40, which is much bigger than 1.5" in inside diameter because it's a 200 year old standard Smile
https://www.metals4uonline.com/PipeSched...ifications
Baldur Gislason
baldur
Baldur Gislason
Mallinman
04-12-2018, 08:22 AM #27
Right I see what you mean thank you. I’ve gone for 36mm ID pipe. I think it will be best suited and the other 42mm ID pipe I have is goanna be too big. The collecter would be a nightmare getting it to fit on the T3
Borgwarner S200
Mallinman
Borgwarner S200
