STD Tuning Engine why wont my camshaft fit?
BoostedW124
04-21-2017, 08:58 AM #1
I am in the process of putting my om606 head back on. I just dropped the hydraulic lifters in Next the camshaft doesnt pop in as a couple lobes are Hung up. Like my lifters are too high not sitting in deep enough. What am doing wrong guys?
1998 w210 e300 TD: egr delete, muffler delete, amg 18s, I love this car!
1995 w124 e300 diesel: bolted on junkyard w210 turbo.. yes you can "easily" boost your om606na! RIP
1991 w201: putting the om606 na to turbo into this. Not enough hours in the day!
BoostedW124
hooblah
04-21-2017, 09:08 AM #2
Sounds normal to me. Got a pic?
hooblah
Evgeniy1987
04-21-2017, 09:25 AM #3
A couple of valves are always open in an assembled engine. This means, if you disattach the upper camshaft bearing caps, the "open" valves will push the camshaft up and close.
Like mr. Hooblah says, sounds normal... but a picture says more than 1 x 10^3 words Smile
Evgeniy1987
BoostedW124
04-21-2017, 09:26 AM #4
No sorry i can't get pics to upload through the website right now. I was thinking to put all the clamps that hold the cams and carefully clamp them down but wanted to hear someone else's input. Last tying i need is to snap a cam...
BoostedW124
AlanMcR
mind - blown
400
04-21-2017, 12:02 PM #5
You need to make sure that the valves that will be pushed down have someplace to go. Is the cam vs. crank timing nearly correct?
AlanMcR
BoostedW124
04-21-2017, 12:58 PM #6
Thanks you answered some of my questions. Ok AlanMcR i think i see what you mean. My pistons are at TDC so if i was to place the cams with the timing marks lining up so the "cam vs crank timing" will be correct then carefully tighten down would be the way to do it because the cylinder wont interfere with valves because that cylinder in question will be down therefore the valves im pushing down by tightening will have "someplace to go". I will await your response before "jumping the gun" ?
This post was last modified: 04-21-2017, 01:13 PM by BoostedW124.
BoostedW124
04-21-2017, 03:42 PM #7
Yes you align the crank to TDC (OT on the damper), the align #1 to inlet stroke where both cam lobes are up (more like in & ex lobes are up at about 2-3 o'clock), the gently wind down the bolts in sequence, 180 degrees at a time or whatever it is.
Been reading up on this because I have to pull the lifters and clean them out because it's clackity clack clack at idle..
Beers,
HH
This post was last modified: 04-21-2017, 03:43 PM by Hario'.
Beers,
HH
