Clutch Upgrade on Dual Mass Flywheel
Hi,
Does anyone know a mild Clutch Upgrade on a OM605 Stock Flywheel for like 200hp?
Ist a 240mm Clutch, will a CDI Clutch and pressure plate (same Diameter) fit the flywheel and the transmission? I read somewhere, that a C 36 AMG clutch should fit, is that true?
Greetings
