STD Tuning Engine gt2860 something smaller?
uli124125
05-11-2017, 03:14 PM #1
hi
im driving the gt2860 on my 602LA 2.5
it start to boost at around 2100-2200
between 2500 and 3000 i have the full 1.6 bar
im looking after a turbo which is a little bit smaller, so i have boost starting around 1800-1900
thanks for help
uli
uli124125
hi
thanks for help
uli
05-11-2017, 09:23 PM #2
Original 605 gt 25. / some have gt20. Is very small device but for 1.6 is enough.
Have u considered a gtv? If so the 22 should make your dream come true.
How much fuel do u have?
uli124125
05-13-2017, 03:41 PM #3
hi
i just thougt about the gt25
i think this will be the right way
vtg wont be the solution my mery runs completly mechanical
about 90 ccm only
uli124125
hi
about 90 ccm only
seanyt
is300d He351ve
279
05-13-2017, 03:58 PM #4
what size exhaust housing have you got on your gt2860?
A/R or cm2
seanyt
A/R or cm2
uli124125
05-14-2017, 12:13 PM #5
the small 0.64
i tried first the 0.86 with gt 2871 this was much too big for my way i use the car
this week im putting back the kkk k24
this setup was almost this what i want with a little defizite of horsepower at high revs
uli124125
the small 0.64
seanyt
is300d He351ve
279
05-14-2017, 02:28 PM #6
i know the om605 guys with the gt2871 0.63 and remaps are getting good results.
But like already mentioned maybe look into a vnt or a he221 if you want more spool and low down.
seanyt
uli124125
05-15-2017, 08:43 AM #7
vnt i dont want to have
with manual tranny the gt2860 is perhaps good
but with automatic it spools too late for about 400 revs
and by using with trailer the gt2860 makes less air and less pressure
whats about a newer form of the kkk k24?
how much variations does this turbo have?
uli124125
uli124125
06-01-2017, 10:25 AM #8
what do you think about the gt2560?
for only 190-200 hp and 1.5 bar from 2200 on?
OM 602
i want to have spooling as early as possible
This post was last modified: 06-01-2017, 10:26 AM by uli124125.
uli124125
OM 602
EbolaTriangle
06-01-2017, 07:30 PM #9
Gt2560r should do you very well. .64 AR. depending on the money you have to spend you you could go efr6758.
EbolaTriangle
