STD Tuning Engine Om606 Failed starter motor?
BoostedW124
08-10-2017, 08:26 PM #1
Hello forum. My 1998 e300 w210 om606 td wont crank over. Turn key and click. Good battery verified. My hunch is starter motor but dont want to throw money at car without being sure. Any suggestions to further diagnose?
1998 w210 e300 TD: egr delete, muffler delete, amg 18s, I love this car!
1995 w124 e300 diesel: bolted on junkyard w210 turbo.. yes you can "easily" boost your om606na! RIP
1991 w201: putting the om606 na to turbo into this. Not enough hours in the day!
BoostedW124
NZScott
HX30W 73/44mm
398
08-11-2017, 05:45 AM #2
Tap the solenoid with a hammer (tap not a whack lol) it might free it up
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
capflya
Dreaming of a VNT
309
08-11-2017, 06:19 PM #3
Is it a click click click like battery is low or just one click that isn't too loud? Like a relay engaging.
If you shift to N does it crank over? These w210's have a few issues from what I've read/experienced.
capflya
BoostedW124
08-11-2017, 09:40 PM #4
Yes just one click like a relay. I heard the keys can wear out but i think mine is fine everything else electronic turns on with key. I guess ill have to take it out and bench test old fashioned way.
BoostedW124
BoostedW124
08-11-2017, 09:41 PM #5
No i tried in neutral Also
BoostedW124
capflya
Dreaming of a VNT
309
08-11-2017, 10:59 PM #6
The EIS (electronic ignition switch) can go out and cause that exact symptom.
capflya
Mr.Emo
Nissan Patrol -> 606 conversion.
69
08-12-2017, 02:05 AM #7
I'm having the same issue but my problem is intermittent, it comes and goes randomly. The glow light and all electronic works but the engine won't crank.
Anyone know where to find a workshop manual for this? I know there is an online version for the w124.
Mr.Emo
AlanMcR
mind - blown
400
08-12-2017, 02:31 PM #8
(08-12-2017, 02:05 AM)Mr.Emo I'm having the same issue but my problem is intermittent, it comes and goes randomly. The glow light and all electronic works but the engine won't crank.
Most likely your problem is the neutral safety switch. Wiggle the shifter the next time it fails to crank.
AlanMcR
Austincarnut
08-12-2017, 08:59 PM #9
(08-10-2017, 08:26 PM)BoostedW124 Hello forum. My 1998 e300 w210 om606 td wont crank over. Turn key and click. Good battery verified. My hunch is starter motor but dont want to throw money at car without being sure. Any suggestions to further diagnose?
Get a strong battery and jump starter relay---make sure its in park @ shifter and transmission
Austincarnut
08-18-2017, 12:40 PM #10
you can reach the + terminal on the starter if you remove the inlet manifold.
My 202 sometimes experiences this I cycle lock & unlock a few times when sat in the car once or twice and it cures it.
So my EIS is on it's way to being borked also.. Dam..
BoostedW124
08-20-2017, 08:16 PM #11
Ok i will remove intake manifold tomorrow and jump solenoid. I checked all fuses, just replaced brake switch although i dont see how that could cause no start and also removed and inspected k40 chip and all is correct. Thank you guys i will let you know soon.
BoostedW124
BoostedW124
08-27-2017, 10:43 PM #12
I took off old starter and swapped in the spare from my w124 na diesel and it cranked and fired right up. Thank you all.
BoostedW124
