STD Tuning Engine Intake/charge temperature sensor relocation
PaddyEnglish86
09-25-2017, 04:16 AM #1
I have just deleted the the EGR Valve on my W202 C250TD and will be re routing the intake pipework straight up from the intercooler into the manifold.
It looks like I need to bring an air sensor across to the pipework. Can I just buy a generic air sensor and hook it up or does the existing sensor need to be used?
Thanks
PaddyEnglish86
Thanks
baldur
Fast
511
09-25-2017, 07:40 AM #2
The existing sensor needs to be used, or one with a similar transfer function.
I believe the transfer function of it is similar or identical to the Bosch units used in many other applications so you should be able to find one that uses a 14mm thread instead of a clip type fitting.
Baldur Gislason
baldur
Baldur Gislason
PaddyEnglish86
09-26-2017, 03:13 AM #3
(09-25-2017, 07:40 AM)baldur The existing sensor needs to be used, or one with a similar transfer function.
Thank you Baldur.
I have had a look around and I cannot find any Bosch sensors with a thread. I have found a few Cambiare sensors that look like they work in the same way but they don't look anything like my one
PaddyEnglish86
Thank you Baldur.
frans-c
09-26-2017, 03:22 AM #4
I just slotted mine in the intake tube between my K&N filter and turbo inlet. Runs fine, with no effect on fuel consumption that I've noticed in about 10 0000 km of driving.
frans-c
PaddyEnglish86
09-26-2017, 09:16 AM #5
(09-26-2017, 03:22 AM)frans-c I just slotted mine in the intake tube between my K&N filter and turbo inlet. Runs fine, with no effect on fuel consumption that I've noticed in about 10 0000 km of driving.
Thank you frans-c.
The one I am talking about is located just before the EGR Valve. So it looks like it is measuring pressurised air temperature. So I will need to hook it up to the new pipework just before the manifold. I just need to find a suitable replacement
PaddyEnglish86
Thank you frans-c.
frans-c
09-26-2017, 03:32 PM #6
(09-26-2017, 09:16 AM)PaddyEnglish86
Thank you frans-c.
Yup, I was referring to that sensor. Many of the other guys simply let it hang loose somewhere out of the way - with no ill effects either.
frans-c
Thank you frans-c.
PaddyEnglish86
09-26-2017, 03:53 PM #7
(09-26-2017, 03:32 PM)frans-c
Thank you frans-c.
Interesting. Do you think it can be unplugged altogether?
PaddyEnglish86
Thank you frans-c.
frans-c
09-26-2017, 04:58 PM #8
(09-26-2017, 03:53 PM)PaddyEnglish86
(09-26-2017, 09:16 AM)PaddyEnglish86 Thank you frans-c.
No, you'll have an engine light then.
frans-c
PaddyEnglish86
09-27-2017, 03:29 AM #9
(09-26-2017, 04:58 PM)frans-c
(09-26-2017, 03:32 PM)frans-c Yup, I was referring to that sensor. Many of the other guys simply let it hang loose somewhere out of the way - with no ill effects either.
Ok I thought that might be the case. Ill give it a go.
I will eventually fit it properly though. I'm not keen on a sensors and wires hanging in the engine bag doing nothing.
PaddyEnglish86
juggs
09-27-2017, 07:31 AM #10
Mine has been running with it unplugged for the last 12 months, not caused me any issues
juggs
PaddyEnglish86
09-27-2017, 11:54 AM #11
(09-27-2017, 07:31 AM)juggs Mine has been running with it unplugged for the last 12 months, not caused me any issues
That's good. What does it actually do then? If unplugging it doesn't cause any problems, why is it there?
PaddyEnglish86
