Throttle linkage balls 603 mechanical pump
Bought this pump a while ago and finally getting around to sticking it on the car. Questions revolve around the oil supply but also the throttle linkage.
First question is on the throttle linkage lever of the pump, which rotates, there are three places for ball fittings. I'm lacking the one that I need for the stock linkage from the na om606. Does anyone know where to get these balls or how to press fit them on to the Armature?
Tanks,
Karl
FYI, These are 8mm balls with a 5mm threaded stud. Same as used on old porsches etc. Need a nut for the back, preferably nylock.
Link: https://www.partsklassik.com/p-2590-scre...169.004.00
