STD Tuning Engine stock turbo power limits om606
elias_799
01-25-2018, 08:59 PM #1
Would  i be able to get 240hp  out of the stock turbo on om606 ?
If not what is a good turbo for my power requerment ?
elias_799
baldur
Fast
511
01-26-2018, 09:40 AM #2
Yes that's about the max for the stock turbo. You just have to make sure you have a good air box and filter. A restrictive inlet will overspeed the turbo and break the shaft.
You'll have to run 1.5 bar boost to make that power.
Baldur Gislason
baldur
Baldur Gislason
elias_799
01-28-2018, 01:34 PM #3
Would a hx30  or hy35 be a better turbo for my power goals ? Or should i just stick with the stock kkk turbo ?
The motor is going in to a pick up truck so i would like the boost to come in as early as possible.
elias_799
baldur
Fast
511
01-28-2018, 05:13 PM #4
If 240hp is your power goal, then you'll be able to do it with the stock turbo and get the best possible response.
I'd forget about a Holset if you want boost as early as possible, they are mostly designed for stationary engines and big heavy trucks. I'd rather use something like a Garrett GT2860 or GT3071 with a small exhaust side.
Baldur Gislason
baldur
Baldur Gislason
