STD Tuning Engine Can anyone help.. what engine is this om606??? I might buy the car if so..
MercMadMicheal
02-06-2018, 05:07 PM #1
Hello, I have come across this merc that I have made a offer for, before buying it for a daily driver I wanted to check wich model engine it was as to use it at a later date in a street rod. If you can help me with this that would be smokeyyy!!
MercMadMicheal
R-3350
Dreaming of compounds
182
02-06-2018, 05:57 PM #2
cant help you without photos or a description
R-3350
NZScott
HX30W 73/44mm
398
02-07-2018, 01:01 AM #3
6 cylinders? Turbo? Plastic cover on top? It should be what you want
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
