Aftermarked Tcu on w211 help needed
Hi! How is it to use examble a ofgear on a w211? Or is there another way to make trans work with tuned engine? Because my transmission goes to safe mode when I pull hard or full throttle in 4th gear.
I offer a plug and play setup for factory cars. Also valve bodies. If you are going into limp while while in 4th and not shifting then you are slipping the transmission. Most likely you need a valve body. You can see my products most easily on facebook. Sound German Automotive
