OM606.910 Blocked inector?
Hi, I have a 606 that had been run by previous owner on used veg oil without any sort of fuel flter! Only for a short while as he couldn't work out why it wouldn't rev over 1500rpm, so bypassed it. Turned out to be a collapsed cat blocking exhaust. Ran absoutely fine for a good few miles, but when removed from car and run on the bench, seemed to be running on only 5. Has anyone ever experienced a blocked injector before? I had one on a vw aaz idi that melted a piston, so am cautious. Will crack lines one by one with engine running and see if I can identify bad cylinder, and test that injector.
Thanks, Jack
