Rebuilt Turbo, Burning Oil and Self-Loathing
I rebuilt my stock Ta031 Garrett a while back and I think the break-in is over.
I plumbed the ccv with a separator so there isn't much oil coming from there. ... it wasn't this bad before the turbo rebuild, so I am left to wonder.
Can the shaft wear even thought the bearings are brass / copper? I thought I felt sections that were worn, but was uncertain. I had it balanced by a tech and I was hoping he would have mentioned anything suspicious - he did not.
The smoke is blue-ish and smells like burning oil. The engine is drinking it as well. If I follow the car and the driver nails the throttle..... it shows.
Turbo is working very well though.
Make sure the engine is breathing well. When I put it my new turbo I was blowing smoke like crazy until I installed a 240D breather.
I think its breathing well... i've collected alot of oil in my catch can.
I've been driving with alot of focus on my exhaust and I'm thinking it might not be the turbo anymore... that thing is tight.
When I dropped my head on last year I inspected all the valves and stems and there was some wiggle going on with the exhaust valves, but I thought the new seals would stop most of the oil....
Maybe the valve stem seals have just loosened up a bit? Once the engine is warm.. the majority of the smoke goes away.
If the guides are too louse they can cause the seals to wear prematurely and fail?
also make sure the oil drain tube is not restricted in any way it has to be a straight drop with no restriction or the back presser! or the oil will force its way past the bearing/seals in the turbo!!!
the valve guides do the real sealing. The seals are more of an 'oil scraper'....
Think of all that hot exhaust getting by the guides and reaching the seals.
--the drain is clear, clear clear.. promise.
What is the size of the breather hose?
That looks adequate, I was just making sure because I had the same problem with the oil smoke and once I fixed the breather I also gained power.
on my car it just dumps into the turbo intake no problems yet! that's the way the factory made it on my 1980 300sd that I got the engine out of!
that blocked off round part on the later turbo intake elbows is where it went to
FWIW I replaced my valve stem seals this weekend, oil smoke after idle is GONE GONE GONE. I think what is left is my turbo on its way out.
(11-09-2009, 02:26 PM)winmutt FWIW I replaced my valve stem seals this weekend, oil smoke after idle is GONE GONE GONE. I think what is left is my turbo on its way out.
(11-10-2009, 04:02 AM)totaldisaster I hear you, man. Did you happen to wiggle the valve stems while you were in there?Yes all #2 were tight and it had only the slightest movement.
(11-10-2009, 04:02 AM)totaldisaster If it was the turbo, it would be smoking like a banshee at high RPMS / high load, right? It only smokes after sitting at a light, on take-off, and before it gets warmed up... but you can always smell it.
(11-10-2009, 05:22 PM)winmutt Yes all #2 were tight and it had only the slightest movement.
Quote:Yes it would certainly be more pronounced at high RPMs. Did you replace the valve stem seals? Your description totally describes the valve stem seals. Smoke after long idle and at startup (burning off what seeped in over night). I was really suprised how much of a difference it was at startup because they sit ~1cm off the head.
