STD Tuning Engine Oil catch can om606?
mower16
05-08-2018, 11:55 PM #1
How many people run an oil catch can on there om606? Worth it?
mower16
MTUPower
288
05-09-2018, 04:39 AM #2
I use a gatorade bottle filled with fishing line; the tube goes all the way down to near the bottom and then a several smaller holes are drilled in the bottle near the top.  The vapor has to filter thru the fishing line and it condenses on it.  Make sure you have enough airflow/holes otherwise it'll choke your engine.  I have to empty the bottle, well, never.  Over 5 years and it had about 2 ounces of oil in it. This is on a modified OM617.
This post was last modified: 05-09-2018, 04:40 AM by MTUPower.
MTUPower
AlanMcR
mind - blown
400
05-10-2018, 12:04 AM #3
Why catch the oil? It will burn nicely in the engine. Problem solved.
AlanMcR
NZScott
HX30W 73/44mm
398
05-10-2018, 02:52 AM #4
Also pools inside intercoolers nicely too?
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
AlanMcR
mind - blown
400
05-10-2018, 12:27 PM #5
There is way too much air flow to let anything more than a microscopic film of oil cling to the sides of the passages.  Not a problem at all.  Also, you get a free boost leak detector, since that film of oil will leak out anywhere that there is a boost leak.
AlanMcR
Mallinman
05-10-2018, 04:20 PM #6
(05-10-2018, 12:27 PM)AlanMcR There is way too much air flow to let anything more than a microscopic film of oil cling to the sides of the passages.  Not a problem at all.  Also, you get a free boost leak detector, since that film of oil will leak out anywhere that there is a boost leak.
Amen to that. That’s how I found my pin holes in my new ally air intake plenum
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
NZScott
HX30W 73/44mm
398
05-10-2018, 07:22 PM #7
Good point, I don't have an intercooler yet so think I'll shut up now Tongue
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
mower16
05-16-2018, 05:23 PM #8
I think it will be one of those things where people are for it and some against it. I spoke to some local performance shops and again some were for and some against it. So I think I don't have a race car, I will save the cash and not run one and get a free boost leak detector.
mower16
