STD Other Projects Nissan td 42 Holset hx30 super
Jimtd42
Slow Nissan
3
05-27-2018, 04:23 AM #1
Hi all I have a Nissan td42 4.2l 6cylinder non turbo and it is slower than slow. I need some boost to make it move I’m lookng for early spool and a long rev range. Power wise I am only running a 10mm fuel pump so at max I will see 140hp at the wheels for now. In future I will upgrade to a 12mm pump and around 200hp at the wheels I know it’s not much but these Nissan cranks snap very easy.
turbo tuners here in Australia favour the td05 18g 6cm ,the garret 2863and 3071 but they are expensive. I have been searching posts for a few weeks and I think the Holset hx30 super would be a good match. I’m only looking to run 15-20psi boost and an inter cooler. The Holset seems cheap reliable and the weapon of choice for the 4bt owners
What do you guys think any suggestions
This post was last modified: 05-27-2018, 04:26 AM by Jimtd42.
Jimtd42
awsrock
300SDL / HX30 / 90cc
179
05-27-2018, 09:00 AM #2
The td05 and 2863 might spool a bit faster / have better response because they have smaller turbine wheels, but they and the HX30 flow about the same on the compressor side. It probably wouldn't be enough of a difference to be worth spending the extra money
awsrock
R-3350
Dreaming of compounds
182
05-27-2018, 09:22 PM #3
the HE221W and the HX30 flow similar amounts while the 221 has a much wider map and spools quite quickly. the only issue is the 221 tends to be harder to find and more expensive. may still be cheaper than a new garrett. Eurotrashmotorsports has them in stock usually.
R-3350
Jimtd42
Slow Nissan
3
05-28-2018, 02:42 AM #4
Thank you for the reply’s I will look into the 221 . Does the hx30 super come with a 4 inch intake
Jimtd42
atypicalguy
05-29-2018, 01:41 AM #5
(05-28-2018, 02:42 AM)Jimtd42 Thank you for the reply’s I will look into the 221 . Does the hx30 super come with a 4 inch intake
Alcaid is your guy for factory direct Holsets of any variety pretty much shipped direct to your door.
Eurotrash seem to be able to get the he200vg, which would be a cool turbo to have for variable geometry or on a compound setup a la erx .
atypicalguy
Jimtd42
Slow Nissan
3
05-29-2018, 03:43 AM #6
I sent alcaid a msg a few days ago is he still active on this forum I’m guessing he is busy. I don’t know much about vnt vgt turbos Or how to control them would a vnt work well on a old mechanical diesel can you retro fit an electronic controlled vnt to a vacuum actuator
Jimtd42
awsrock
179
05-29-2018, 02:57 PM #7
I'm not sure Alcaid is around anymore. Hopefully he is, but have not heard from him in a while. You might just have to wait a bit to hear from him, or try to track him down on another forum
awsrock
NZScott
HX30W 73/44mm
398
05-29-2018, 09:31 PM #8
I tried hitting Alcaid up when I wanted my HX30 but he must be busy (had gotten my HE200 off him), that was over a year ago, ended up getting one of ebay (just a standard not a super).
There is these guys too http://www.compressorracing.com/
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
