STD Tuning Engine OM602 dimensions
OM602 dimensions
OM602 dimensions
buzzboy
08-13-2018, 07:49 AM #1
I'm dreaming of give my e36 an STD. DieselPumpUK sells an OM60x to BMW ZF320 adapter that caught my eye.
I've measured an OM603/606 and it is a bit long and will foul the radiator by a full inch. Oh well. So what about an OM602? If anybody has an OM602 they could take a few measurements from I would be in your debt.
Bellhousing to front pulley length
Engine height from shallow end of oil pan
Engine Height from crank centerline to top of valve cover
buzzboy
baldur
Fast
511
08-13-2018, 03:06 PM #2
I measured my engine, but note that I have a Ssangyong truck engine so the sump is slightly different (rear sump).
From bellhousing to front of the pulleys 69cm
From crank center line to top of valve cover 43cm
From crank center to bottom of shallow end of sump 18cm.
Baldur Gislason
baldur
Baldur Gislason
buzzboy
08-13-2018, 06:55 PM #3
Exactly what I was looking for. Thanks so much.
buzzboy
