STD Tuning Engine OM 642 Injector Compatibility
Austincarnut
01-31-2019, 06:55 PM #1
Do any of your out there know or have tried to use 642 PC injectors in a sprinter and vice a versa?
I have a set of 6420701587's and a 211.022 with 2 dead injectors.
Austincarnut
starynovy
02-02-2019, 02:07 PM #2
If the bosch number dont match you cant use them. Simple as that. Well you can of course but not without recalibration of ECU otherwise clodged DPF all the time and other problems.
starynovy
02-07-2019, 03:16 AM #3
Haha. Sorry sorry.
Most probably the 642 injector only differ from 611 on the coil settings, and of course nozle... as one 1250 bar and the other is 1500.
Do they run , yes they do does the engine works well most probably yes.
What canot be done is using only 2 in a set of 4.
Ecu recalibration yes but that u should do everitime u change injectors. Calibtation with a new part number.
Haha. Sorry sorry.
