STD Tuning Engine OM603 superturbo question
Lången
06-09-2019, 10:18 AM #1
How much boost can i put in to my om603? It has homebuilt extractor, hx35 #12 separate 50mm wastegate. 3" exhaust. 7.5mm pump. Is it safe whit 1.5 bar?
Lången
06-09-2019, 10:50 AM #2
That is gay boost ...
Lången
06-09-2019, 10:32 PM #3
Haha ok...how much boost shall i go for?
Lången
Anjay1
06-10-2019, 12:11 PM #4
At least 2 bar.
Anjay1
At least 2 bar.
Lången
06-15-2019, 06:36 AM #5
Can the motor handle 2 bar on a daily driver?
Lången
Anjay1
06-15-2019, 11:14 AM #6
It will be fine. Boost at that level is only while you accelerate. Once you get to speed it will settle to much lower level as demand for fuel will be less.
Anjay1
awsrock
300SDL / HX30 / 90cc
179
06-18-2019, 09:14 PM #7
Herlevi pump builders told me stock 603 headgasket can handle 2.5 bar but obviously if its old maybe a bit less
awsrock
Lången
06-20-2019, 03:48 AM #8
Sounds good!
This post was last modified: 06-20-2019, 03:49 AM by Lången.
Lången
Sounds good!
Mallinman
06-20-2019, 01:15 PM #9
How much pressure can the stock 606 head gaskets take then??
Mitsubishi L200 manual om605
7.5mm Bosch 044 fed pump
Borgwarner S200
Mallinman
Borgwarner S200
