STD Tuning Drivetrain 722.6 V-8 bellhousing used for conversion.
Blackstack
07-02-2019, 12:47 PM #1
Does using a 722.6 transmission with a bellhousing from say a 5.7L V-8 Mopar allow for more possibilities for different convertors than swapping on an inline 6 bellhousing that bolts right up?  In other words, does using the correct bellhousing for a OM606 limit your choices for different and/or aftermarket convertors for the 722.6?
Blackstack
firen456
07-03-2019, 12:39 AM #2
simply yes. Only small converters fit in the inline housing.
firen456
whipplem104
07-14-2019, 02:04 PM #3
Why would you want put a different converter in? For a higher Stall? if so just have yours modified. It is cheap and easy to do.
whipplem104
