STD Tuning Engine M103 w201 -> OM606 swap
keiffith
12-11-2019, 09:38 AM #1
I'm in the US so it took years to source an OM606. Found one 1 mile from my house.
I have a M103 auto w201 that I want to swap.
What I know
-w124 mounts with stock w210 arms will bolt in after 10mm is shaved from the mounts
-vaccum cutoff
What I need to know
-will the front AC fan be adequate enough for cooling if wired to turn on at 85-90*C
-what rad hoses to use with my stock radiator
Where to pin the glow plug harness into the stock location (doing push button so I just need to know where it normally gets power)
Will the m103 p/s pump and a/c comp bolt to the om606
Thanks for the help
keiffith
What I know
-vaccum cutoff
What I need to know
Thanks for the help
Bigpanda16
12-14-2019, 10:37 PM #2
Use a ford remote starter solenoid for the glow plugs.
All the accessories should bolt up, the block is essentially the same. Even the oil pan would bolt up
78 300D, 87 190D, 94 E320, 95 E300D
Bigpanda16
benzguy
12-17-2019, 03:14 PM #3
I don’t think you can use the radiator from the 103 engine different position water outlets I did a similar swap I used a radiator from the 190D turbo
benzguy
benzguy
12-17-2019, 06:57 PM #4
The p/s will work with the 606 but a/c compressor will not bolt on use the 606 accessories
benzguy
Ace
11-06-2021, 07:50 PM #5
hallo,
wie weit ist der umabu ich plane den selben gerade ich deutschland
ich habe das problem mit der wegfahrsperre bei der elektronischen pumpe hast du da eine lösung gefunden ?
mfg
Ace
hallo,
mfg
Steve77
11-07-2021, 05:29 AM #6
@Ace:
Here is described, how to run the OM606 standalone with the OEM-Ecu: http://www.superturbodiesel.com/std/show...p?tid=7547
I am from Germany too, but I think, it's better to write in English in this forum.
Steve77
@Ace:
Ace
03-28-2022, 10:08 AM #7
(11-07-2021, 05:29 AM)Steve77 @Ace:
Hier ist beschrieben, wie man den OM606 Standalone mit dem OEM-Ecu betreibt: http://www.superturbodiesel.com/std/show...p?tid=7547
Ich komme auch aus Deutschland, aber ich denke, es ist besser um in diesem Forum auf Englisch zu schreiben.
hi,
Ja das mag sein  nur leider ist mein eng mehr als schlecht  Dodgy Dodgy
mfg
Cord
Ace
hi,
mfg
Cord
